First post, by auron
i have this '98 ATX astec power supply, its very compact dimensions make it convenient to use outside of a case and it looks like a decently built unit with all chemicon/nichicon caps. its total output is lower than usual however, 110w. the specs are +12V 3.5A, +5V 10A, +3.3V 4A, -12V 0.8A, +5VSB 0.1A. any ideas for practical limits on this, is a klamath with some AGP card and usual peripherals pushing it?
inside pics attached.
    715.26 KiB
    1009.01 KiB
Reply 1 of 8, by PC Hoarder Patrol
Should be OK with care...I've an Astec unit stripped a few years ago from an old Medion system (AGP-less MSI OEM ZX board, P3 coppermine 650MHz, 512MB PC100, hdd, optical & floppy) still going strong today for testing & temp builds - recently had a spring clean inside Re: What retro activity did you get up to today?
Reply 3 of 8, by auron
it does seem like one of the few PC PSU brands that did use japanese caps pretty consistently in the 90s, which can't even be said for seasonic. i do however have another 200w astec unit from 2000 that does partially have jamicon in it, so they started skimping a bit on caps as well, at least on some units. more than anything i'm not using that one because one PCB corner is cracked, though.
recently came across this old thread and was a bit surprised seeing a report of an astec PSU causing a motherboard to burn up: Building a Pentium Pro system from scratch
Reply 4 of 8, by Horun
That 110watt supply is a very low end meant for Celerons and onboard video, not really for anything with a add-on video card or AGP slot. In fact would not power a good ATX Pentium or Pentium Pro system. Yes some Astec's were notorious for not having over volt/overload/short circuit protection. I would not use that to test any motherboard my self but feel free to experiment.
Reply 5 of 8, by brian105
Really? I have a 110W Mitac PSU in a SS7 PC I wanted to upgrade, possibly with a GeForce 2 card. I thought that parts of the time didn't use much power? i.e. K6-3 using 30 to 40W max, GPUs using up to 10W, etc.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 6 of 8, by darry
brian105 wrote on 2020-06-06, 03:32:
That 110 W max would not be that bad if you did not have additional per rail maximums, but even if we don't take that into account :
CPU 30W (K6-2 475) https://en.wikipedia.org/wiki/List_of_AMD_K6_microprocessors
Video card 25W (can't find any formal figures for Geforce 2 GTS, but 25W for a Geforce 3 ti 200 is a figure I have seen floating around)
Motherboard 8.5w at least estimated (686B use 2.5W, could not find specs for MVP3 or MVP4, but 430TX is 1W, and at least 5W for VRMs, super IO, etc , probably too conservative)
Addition card 7W each estimated (at least 1 sound card, I imagine)
RAM 5W ( 0.1 A at 3.3V per chip typical, so about 2.64 W per 8-chip DIMM, so about 5W for 2 DIMMs)https://webcache.googleusercontent.com/search … t=clnk&gl=ca#25
Hard drive 7.1W at idle (as an example of a period drive https://www.hdsentinel.com/storageinfo_detail … l=WDC%20WD400BB)
CD-ROM 27W (0.6A on 5V and 2A on 12V https://www.recycledgoods.com/mitsumi-24x-ide … ve-crmc-fx240s/)
Total 109.6W
EDIT: And even if the GPU is closer to 10W, you're still cutting it close, IMHO .
I would say you are living dangerously .
Reply 7 of 8, by brian105
Luckily, integrated sound. But still, that's cutting it pretty close.
