First post, by ykot
I have been playing with my FIC 486-VIP-IO motherboard. It came with BIOS from year 1995 without support for newer CPUs, with Y2K bug and floppy issue similar to the one described in this post.
There are two newer BIOSes available at this location, one is 427GN2A dated 1996 and another is 3276GN1 dated 1997. The last one does work with the board, seems to support newer CPUs, has Y2K bug fixed and makes floppy controller working again! However, it does not initialize PCI bus, so even a PCI post card won't read any post codes with that BIOS, even though everything else will function fine (tested board with ISA graphics card and Cyrix 5x86 CPU). This can be confirmed using ModBin utility - in the first binary there are four PCI slots, whereas in second there are none.
I was wondering if somehow PCI ROM could be transferred from 427GN2A to 3276GN1? I have tried CBROM utility to see if anything can be extracted (looking at HEX dumps I can see Cirrus Logic BIOS ROM present in the second image, so there should be some entries) but it doesn't recognize the binaries. Any help would be greatly appreciated.
