First post, by svfn
Finally found a decent beige case that isn't so seasoned. The front panel is strangely held by these metal things. Does anyone know if it pops out like plastic clipped ones, or it needs some tools to remove the bits? Since I've broken some plastic clips I don't wanna force anything again 🤣.
SS7: K6-2/350 | FIC PA-2013 2.1 | 32MB PC-100 | 3dfx V3 2000 AGP | AWE64 CT4520 | Win98SE
On MobyGames
Reply 3 of 3, by svfn
It does come off with a loud satisfying crack! Now I can get to the dust inside 😜 Also seems much sturdier than the usual plastic clips that get brittle. The front blue bezel also pops off, perhaps it was a swappable color thing. Maybe it looks better all beige 😜
355 KiB
The metal clips are screwed in place.
pentiumspeed wrote on 2020-09-19, 20:25:
Can you show the rest of case external and internal?
It looks fairly generic on the outside, but build quality is much better than what I had or could find locally.
123.18 KiB
With blue bezel.
130.45 KiB
Is this supposed to be for airflow intake lol.
1.22 MiB
Seems like it has holes for AT.
On MobyGames
