First post, by pokeswithastick
I bought a couple of n600c laptops with a view to combining parts and making one that was in good overall condition for retro gaming. Both were fully functional on arrival which I tested by swapping out a hard disk with Win98 SE installed.
Then I did a silly thing.
The docking station connector on one laptop was slightly managled so I stuck a penknife blade in to clear out the broken bits of plastic. I did this while it was off but plugged in to the power adapter (very silly). One small spark later and the sound chip is no longer detected in Win98 SE. Also the laptop hangs on any non-physical restart whether it is from the OS or from the BIOS (Save and Exit).
Other than that there are no obvious issues - it POSTs, it boots, everything else 'works'.
I removed the motherboard to give it a quick visual inspection and I don't see any obvious damage. I wonder if anyone has a clue what the cause might be just for my curiosity. I was wondering if perhaps the laptop now thinks it is permanently docked or something like that.
Thanks.
Reply 1 of 7, by adalbert
Do you have a multimeter? You can look for the fuses on the motherboard and check the continuity. I don't know where they are on that motherboard, some high resolution photos would be helpful.
It would also be helpful to mark where exactly you put the knife on the docking connector when you saw the spark. On page 187 there is the pinout of the connector http://h10032.www1.hp.com/ctg/Manual/c01122797.pdf
and we can guess what was broken by the short circuit.
Reply 2 of 7, by pokeswithastick
Yes I have a multi meter so doing some continuity tests shouldn't be a problem.
Here are some high res images.
1. Damaged docking connector. You can see where it is bowed and this is where I ran the penknife blade through.
preview
2. Bottom side of the motherboard - docking connector is top right
preview
3. Underneath the plastic sheet where the docking connector is soldered to the board
preview
4. Top side of the motherboard - sound chip is top right (ESS Alegro)
preview
5. WIth DC/DC converter removed
preview
6. Other side of the docking connector
preview
Reply 3 of 7, by adalbert
You could check components marked F and L for continuity. You could also try measuring the voltage on VCC pin of sound chip, to see if it gets any power when the board is turned on. But here you would need to be careful too, in order to not cause more damage by touching multiple pins. Maybe the VCC pin is connected to a nearby capacitor, and you can check the voltage on that capacitor, which would be easier.
    124.94 KiB
Reply 4 of 7, by pokeswithastick
No continuity problems. I also removed cpu heatsink and fan and found a couple of extra fuses but these check out ok too. Guess I will try the VCC on the sound chip itself next.
file.php?mode=view&id=94689
Reply 5 of 7, by pokeswithastick
Some progress. This bus controller IC gets really really hot - too hot to touch after a few minutes of the motherboard being powered up. Given its proximity to the docking connector that would seem to make sense however I'm not sure if the fact it is getting hot is because it itself is shorted internally and needs to be replaced or if it is the victim of a short elsewhere.
I'll source a replacement anyway and try to desolder.
Reply 6 of 7, by adalbert
You might look for shorted capacitors (tantalum, ceramic). But maybe it is a problem with that IC. If you have hot air station you can desolder it, if not you can carefully cut the pins with razor (near the body of that IC) and desolder them one by one. If a replacement IC is cheap.
Reply 7 of 7, by pokeswithastick
I desoldered the chip using the second method, cleaned up the pads and the laptop is happy to POST without it and does now reboot properly when exiting the BIOS. Reading the IC specs I think this is simply a bus connector for the docking port so I may well be able to get away without a replacement as I don't plan on using it that way.
Now to re-assembly. I took the all of the plastic sheets off the various parts of the motherboard. They are pretty disgusting to I'll probably cut some replacements but does anyone know what kid of adhesive to use - sticky but not permanent sticky.
Thanks in advance.
