First post, by Wilius
Hello
I have a Gigabyte GA-6BX7+ motherboard and would like to upgrade the CPU.
According to Gigabytes website, the Pentium III 1.1GHz and the Celeron 1.1GHz (Coppermine) are the fastest FSB100 CPUs supported on this board.
In order to run this CPU at the correct frequency, one has to adjust a set of dip switches.
The problem is, that the frequency table in the manual only lists the multiplier up to 9.5. The Celeron 1100 however has a multiplier of 11.0.
Does anyone know, in which order I have to set the Dip switches, to run this processor at the correct speed?
Thanks in advance.
Reply 1 of 14, by Thermalwrong
The CPU has a fixed multiplier, so it should be 11x regardless of what multiplier you've got specified on the motherboard. I think?
Just the voltage and FSB matter with socket 370 CPUs.
Reply 3 of 14, by Wilius
Thanks Thermalwrong and red-ray
You were right! How silly of me.
Sorry for my stupid thread.
BTW. I don't want to sound rude, but perhaps, you slipped a line red-rey.
It says N/A for the P3-Celeron 1.4G. Besides that, this board does not support Tualatin.
Reply 5 of 14, by Wilius
Thank you, that's awesome!
Reply 6 of 14, by Wilius
I've got yet another dumb question.
Is there a way to modify this board to allow it working with Tualatin?
I know that adapters exist, but i'm not looking into getting one, because they're pretty rare and expensive.
I've heard, there were some socket 370 and slot1 boards with the 440bx chipset that could be modified to run with Tualatin.
But, i've never seen anyone who tried getting Tualatin to work with this specific board.
Reply 7 of 14, by mastergamma12
If it can support 1.45v like my P3C-E can, you'd still need a converter or a pin modded Tualatin as I doubt the board is FCPGA2.
Reply 8 of 14, by Wilius
I should have expressed myself more clearly. I am looking for a pinmod.
Do you happen to know any pinmod, that potentially could work with this board?
Or can you provide me to a source?
Thanks in advance for your help
Reply 9 of 14, by mastergamma12
Wilius wrote on 2020-11-23, 05:20:
I should have expressed myself more clearly. I am looking for a pinmod for this board. Do you happen to know any pinmod, that po […]
I'm afraid I won't be able to help you with that.
Good luck though.
Reply 10 of 14, by Wilius
Thank you! I appreciate it.
Perhaps getting a board that supports Tualatin is smarter anyways.
Till then, I'll stick with my Celeron 1100.
Reply 11 of 14, by Paadam
It is easy to modify this board for Tualatin, I had GA-6ZMA (mATX with 440ZX chipset) back in 2004-2005 working with Celeron 1.2 GHZ @ 1.6 Ghz (133 MHz FSB) after I tested few samples, B steping worked well.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 12 of 14, by Wilius
Cool, that sounds intriguing! Can you please tell me, what exactly you modified on this board?
Is this mod only working for Slot1 Boards, or does it also work on socket 370 boards as well?
Reply 13 of 14, by slartibardfast0
Wilius wrote on 2020-11-26, 13:23:
Hi! I'm not sure if it's permitted to post eBay links? But this summer I purchased a pre modified Celeron Tualatin CPU for a slot key adapter on an ASUS 440 BX from this user, really recommend their work!
https://ebay.ie/usr/user8012
Reply 14 of 14, by Wilius
Thank you for sharing this link.
I'm looking forward to purchase one in the future.
It'd be interesting to see, whether it's going to work on this board.
