First post, by Steapa
Hello!
I bought a CF-IDE adapter to use on my MICRO-STAR MS-4138 / 486SI5 VESA socket 3 motherboard. I'm using a 1GB card, but the BIOS won't auto-detect it, and on POST it shows "Primary HDC error". If I use a 512 MB HDD it detects just fine, so the controller card is not the problem. Maybe is a mobo limitation? I don't have a smaller card at the moment, but I thought that 1GB wasn't that much. What should I do?
This is the adapter and card I'm using, it connects directly to the ide port:
Reply 1 of 3, by pshipkov
I hit some problems like this before.
It is the IDE controller actually.
retro bits and bytes
Reply 2 of 3, by Pierre32
You can hit numerous snags using CF cards. The big likelihood here is that your BIOS has a 512MB drive limit. You can address this with drive overlay software like EZ-DRIVE.
Sometimes though, the card just won't play. I've had cards throw controller errors, but swapping to another brand (the same size) worked fine.
Reply 3 of 3, by Steapa
Thanks for the replies.
Both Ez-Drive and OnTrack Disk Manager did not work for me, they can't find the cf.
I tried to use it on another motherboard with award bios from 1995 with LBA and it detected normally.
I also tried to insert the parameters that I got from the other mobo, but it also did not work:
C:995
H:32
S:63
L:1990
Disabling LBA mode did not change anything. I also tried three different controller cards to no avail.
I also forget to mention that the first mobo has an Amibios from 1994.
I'm getting a bit hopelessly.
