First post, by Jackal1983
I have a ISA NIC based on the DP83800AVF 10/100 ISA MAC chipset. Since it has an option rom socket (28 pin, but that's not an issue) I'd like to use it to run the XT-IDE bios at startup in a 286 build I'm contemplating. However I have had precisely zero luck in finding any info or software for it so I can figure out what size chips it likes or how to configure it to run the option rom at boot. Packet drivers and other DOS utilities are also a no go. The killer? It's an Intel branded card (EtherExpress Pro/100 LAN Adaptor), you think there'd be some documentation! Any ideas? I'd hate to junk it, because the thing is new old stock.
Reply 1 of 12, by PC Hoarder Patrol
Jackal1983 wrote on 2021-04-08, 02:18:
Best driver option seems to be these which are listed on the Intel Support page on archive.org
Driver - https://www.helpjet.net/Fs-55764671-10843694-93119684.html
Support - https://web.archive.org/web/20021005011141/ht … 00isa/index.htm
Manual - http://cwcyrix.duckdns.org/intel-legacy-files … er/100iguid.pdf
You can also check here, where there still seems to be other Intel docs & drivers
http://cwcyrix.duckdns.org/intel-legacy-files … ive/LAN/Legacy/
http://files.mpoli.fi/hardware/NET/INTEL/
and you can find the National Semiconductor DP83800 Software Programmers Guide here
http://bitsavers.trailing-edge.com/components … tes/AN-0995.pdf
Reply 2 of 12, by Horun
Good work PC HP !
Over at valdex found the Pro/100 boot agent doc that describes using a Network BOOT rom (and mentions 64k rom) and some how too's...
Reply 3 of 12, by Jackal1983
PC Hoarder Patrol wrote on 2021-04-08, 04:53:
Best driver option seems to be these which are listed on the Intel Support page on archive.org […]
Horun wrote on 2021-04-08, 23:28:
Good work PC HP !
Thanks to both of you. Guess I've got a lot of reading to do. Hopefully one of those links contains a packet driver.
Reply 4 of 12, by Horun
The driver link posted above does have the Config.exe needed to set NIC parm's and includes the DOS Client/LAN Manager and DOS Packet Driver.
Reply 5 of 12, by Jackal1983
Horun wrote on 2021-04-09, 00:14:
That'll help. Which file is the packet driver?
Reply 6 of 12, by PC Hoarder Patrol
If you download & run the compressed driver file (100IDISK.EXE) from the link I posted above, it'll expand all the various OS driver options including a directory named PCKTDRVR - the files you want are in there.
Reply 7 of 12, by Jackal1983
PC Hoarder Patrol wrote on 2021-04-09, 01:19:
Thanks!
Reply 8 of 12, by feipoa
I use these EtherExpress Pro/100 ISA cards in about half a dozen systems and haven't had any problem with them. They are much cheaper than the rarer 3Com 100 mbit ISA card.
Reply 9 of 12, by Jackal1983
feipoa wrote on 2021-04-09, 04:24:
Any issues getting the XT-IDE bios running on them?
Reply 10 of 12, by feipoa
lol, haven't tried yet. covid has [indirectly] shutdown my hardware activities. But they work great as isa network cards. I figure 100 mbit ISA could be a collector's item soonish. Think I saw a 3Com 10/100 go for almost $200 a few years ago.
Reply 11 of 12, by Jackal1983
feipoa wrote on 2021-04-09, 05:21:
🤣, haven't tried yet. covid has [indirectly] shutdown my hardware activities. But they work great as isa network cards. I figure 100 mbit ISA could be a collector's item soonish. Think I saw a 3Com 10/100 go for almost $200 a few years ago.
Might just buy a Doublerom board (an EEPROM burner might turn out useful) with both versions (the small version and the larger version) of XT-IDE on it and whip up a 30 pin to 28 pin adaptor from a 30 pin socket and just try both in the NIC. If it doesn't work, I can eventually pickup a 3com NIC (there's an Etherlink 3 up right now for 25 bucks shipped) for use as a host for the BIOS (that's the primary purpose for the NIC, networking is a nice to have for the future thing) and use the Intel/NS NIC in my Slot A T-Bird build or my MediaGX build. Either one could eventually act as a file server to the 286. It'd be less of a pain than swapping CF or SD cards in and out. I wasn't aware 10/100 ISA cards were that uncommon. Interesting. I got mine as NOS surplus for about 25 bucks shipped about a year ago to go in a SS7 build I was working on. I'll definitely use it in something, to be sure. That slot A build might actually be a better candidate: dual boot a stripped down XP install to run GOG installers and dump the unpacked files onto the 286. Food for thought to be sure.
Reply 12 of 12, by chrismeyer6
I have all of our computers on the network it really does make life super easy for transferring files and printing. My 6 year old loves to play all the old Magic School Bus games and he likes to print out different pictures and activities and having printer sharing makes that easy.
