First post, by Monteto
I have an IBM PS1 2133 (surface mounted 486SX 25 MHz) I have been upgrading lately, and I want to get more out of the system by upgrading the CPU. Currently I am running a 486DX2 66MHz underclocked at 50 MHz in the upgrade socket (I did the necessary hardware hack to get non-overdrive processors working in that socket, thanks to epictronics for the know-how).
I am aware that all the alternatives listed below would require a voltage regulator adapter, further hardware hacking or a processor with integrated voltage regulation to get the necessary 3.45V or 3.3V instead of the original 5V to the processor.
I know there exists some AMD Am5x86 and Cyrix Cx5x86 models that actually support 25x4 MHz for a 100 MHz system, but I haven't been able to come by any of these.
My question is: can I expect 4x33 processors to work on my system underclocked at 100 MHz? Or will they just simply not work? Some sources mentions the Cyrix processors require 33 FSB, but I suspect this is only for maximum performance. There seems to be a lot more of these processors around than the 25x4 ones.
I do not want to switch the crystal for a 33 MHz FSB on this motherboard as I think it will stray to much from the original and I also don't know if I feel competent enough (seems harder on this board than others I have seen modified).
IBM PS/1 2133 540 10 MB RAM 486SX 25Mhz
Reply 4 of 20, by debs3759
Cyrix 5x86 with 4x multiplier are for the wealthy these days. I've seem Cx5x86-133 sell for over $500 🙁
Reply 5 of 20, by appiah4
debs3759 wrote on 2022-08-04, 13:44:
Dafuq?
Reply 6 of 20, by rmay635703
appiah4 wrote on 2022-08-04, 14:15:
Dafuq?
I thought some of the lower speed grades sometimes had X4 enabled instead of just x2-x3
Don’t remember anymore how you identified one from the other
https://forum.vcfed.org/index.php?threads/cyr … 6-133mhz.20956/
Reply 7 of 20, by debs3759
rmay635703 wrote on 2022-08-04, 16:04:
I thought some of the lower speed grades sometimes had X4 enabled instead of just x2-x3 […]
Dafuq?
Some that aren't officially 4x are capable, but it's a lottery. I must get round to testing the 3 x 5x86 I have 😀 I think the are some Cx5x86-100 that are 4x 25 as well, they may be cheaper. I've stopped buying so much lately, so not sure.
Reply 8 of 20, by Disruptor
Monteto wrote on 2022-08-04, 12:51:
I am aware that all the alternatives listed below would require a voltage regulator adapter, further hardware hacking or a proce […]
An Am486/"5x86" /133 will work with 25 MHz as well as it would work with 33 MHz FSB.
Despite the requirement for the voltage reduction:
1) On some motherboards the CPU initialisation may fail because the BIOS does not know what to do with that CPU.
2) With a higher multiplicator the L1 cache's operating mode write-back will become more important. If your board does not support write-back CPUs, you won't get a performant system. Don't expect too much if you have to run your CPU in write-through mode.
3) The new CPU will have a double sized L1 cache. This may lead in a performance benefit tough.
You should be aware that there is a service manual online:
http://ps-2.kev009.com/pccbbs/aptiva/63g2028.pdf
Perhaps you have more benefit from installing a Pentium Overdrive...
Reply 9 of 20, by Monteto
Disruptor wrote on 2022-08-04, 17:40:
An Am486/"5x86" /133 will work with 25 MHz as well as it would work with 33 MHz FSB. Despite the requirement for the voltage red […]
Thank you for really interesting info to take into consideration!
I do not really know if the board supports write-back or not, I will do some research. Thank you for the link to the service manual, however it does not list my exact configuration (it seems like there was a lot of different PS/1 configurations haphazardly tossed out there without much documentation , but one of them gets close. This is an European model.).
It also seems like it is suddenly more 100MHz than 133MHz Cyrixes available for a reasonable price (not the case last time i searched ebay), so I might try to buy a couple and see if I get lucky and it has a 4x multiplier 😀
Very hard to find voltage regulator adapters though....
Reply 10 of 20, by appiah4
Monteto wrote on 2022-08-04, 21:59:
Thank you for really interesting info to take into consideration! […]
Try to find IBM branded Cyrix 5x86s, they reliably work at 120MHz (40x3) and with registers enabled easily match Am5x86-133
Reply 11 of 20, by Monteto
But that will leave me with 75MHz with my 25MHz FSB(25x3)? What I need is certainly 25x4, or rather 33x4 underclocked to 25x4?
Reply 12 of 20, by GigAHerZ
Just a remark - if you want more speed, try to get AMD's 5x86 instead of Am486. The 5x86 has double the L1 cache, which is really nice to have when the FSB speed is low. 😉
Reply 13 of 20, by appiah4
Monteto wrote on 2022-08-05, 09:11:
My remark was advice in general, in case you own a board that does 40Mhz at some point. Otherwise what you want is an AMD Am5x86-PR75 (or -133; same part).
Reply 15 of 20, by werfu
Had any luck? I got my hands on a PNY Powerstacker (an interposed AM5x86-P75) and I'm trying to get it to work with a PS/1 2133-F43 (originally with a 20Mhz CPU) but I can't get it to POST 🙁
Werfu was here
Reply 16 of 20, by AlessandroB
werfu wrote on 2022-10-21, 19:18:
In my IBM 486 Intel CPU work all models, AMD 5x86 no way to make it boot, Cyrix 5x86 work correctly (no tuning, just the cpu) Pentium Overdrive Work but only with the Hard disk in the second ide channel. IBM are not the compatibility-Champion
Reply 17 of 20, by Sphere478
4x25 for 100 is no problem.
Btw, if you do come around to the idea of a voltage interposer check out the socket 1/2/3 voltage interposer tweaker
Re: Socket 1/2/3 Voltage Interposer Tweaker (Alpha, seeking testers)
Currently seeking alpha testers.
Sphere's PCB projects.
Reply 18 of 20, by rmay635703
IBM went to great lengths to cripple their boards from being upgradable.
My guess is any chip you install needs to support the overdrive pinout to disable your soldered chip.
Best bet are Intel DX2-4 and p24t overdrives, a 5x86 overdrive would need to support the overdrive pinout and not all did.
Unfortunate that it’s so hard to find BIOs upgrades for all the IBMs, IBM was even stingy in distributing bios updates unless you bought official upgrades from them that required an upgrade.
My school library had original generation IBM model 25 286’s upgraded to SLC chips and they got updated bios’s in the package so the systems actually posted with the correct info.
Have to imagine it was a pretty penny getting IBM certified upgrades let alone having an IBM maintenance agreement and network
Reply 19 of 20, by Sphere478
rmay635703 wrote on 2022-10-22, 02:04:
IBM went to great lengths to cripple their boards from being upgradable. My guess is any chip you install needs to support the o […]
Can anyone tell me what exactly about the overdrive pinout it is that disables the chip? Is it the same as the 487 main processor disable signal? Because the tweaker can do that. But if there is another signal I can add it also.
