First post, by Paul_V
Hi,
I got my hands on a motherboard, which was meant to be scrapped for parts and presumed to be dead.
After replacing faulty caps, busted regulator and transistors, I've been able to get it running.
This is a model GA-5SMM, which seems to be a Gigabyte brand motherboard, which was also used in Compaq Presario PCs
I could use some help in gathering some additional info:
1) Currently, this motherboard is flashed with Compaq BIOS v1.2, which has boot logo and a very limited setup.
Does it hold any collectors value? I'm about to flash it with Gigabyte's BIOS
2) Are there any resources, which have info on which Compaq models used this motherboard?
Could not even find any photos or sources on Presario 5410, 5420, 5423, 524
3) This particular motherboard seems to have issues powering up with some PSUs.
At least two out of five PSUs I have refused to power up. Others work perfectly fine, no voltage dropout or shorts.
Should I investigate further, or is it normal perhaps? (high 5v stb demand or low PGD delay, idk)
    3.38 KiB
    3.53 KiB
    1.2 MiB
Reply 1 of 5, by greasemonkey90s
In because im interested to see if this can be safely flashed to retail gigabyte bios. I have the same board with compaq bios.
In a nutshell its not a favorable chipset but its highlights its one of the few that can be overclocked to 133fsb. The asus version of this chipset is the most sought after followed by the retail version of this one. With wpcredit tweaks it can be made to be pretty good.
Reply 2 of 5, by Paul_V
greasemonkey90s wrote on 2023-04-13, 15:01:
Don't see a reason why it wouldn't work.
Just checked with gigabyte's flash848 utiity - the BIOS flashed and works fine (F5 revision).
But I cannot recommend doing that unless you own a programmer.
UPD:
I'm uploading original Compaq BIOS dump v1.2, just in case somebody needs it.
    Compaq_GA_5SMM_dump.rar
    139.51 KiB
    40 downloads
Reply 3 of 5, by Horun
Good work ! Yes some older ATX boards have issues with newer ATX psu. Have a few old ATX boards that refuse to start with any newer ATX spec PSU after 2005. Something to do with the ATX12v spec board is expecting being 2.01 or earlier afaik...though a few listed as 2.03 do work on those same boards (about 2004 era IIRC). Anything newer and a no go !
Reply 5 of 5, by Paul_V
Horun wrote on 2023-04-14, 00:13:
I see, thanks.
Well, I may consider myself lucky twice. )
First time when I chose a compatible PSU, saving A LOT of troubleshooting time.
Second time, when a faulty regulator just shorted itself, causing a voltage drop on output and saving other components on it's path from being blown up.
jakethompson1 wrote on 2023-04-14, 02:59:
The onboard ESS Solo-1 is one of the more DOS-compatible PCI sound cards too.
This and onboard video is actually the reason it caught my eye in the first place.
