First post, by Paul_V
- Member
I got my hands on a motherboard, which was meant to be scrapped for parts and presumed to be dead.
After replacing faulty caps, busted regulator and transistors, I've been able to get it running.
This is a model GA-5SMM, which seems to be a Gigabyte brand motherboard, which was also used in Compaq Presario PCs
I could use some help in gathering some additional info:
1) Currently, this motherboard is flashed with Compaq BIOS v1.2, which has boot logo and a very limited setup.
Does it hold any collectors value? I'm about to flash it with Gigabyte's BIOS
2) Are there any resources, which have info on which Compaq models used this motherboard?
Could not even find any photos or sources on Presario 5410, 5420, 5423, 524
3) This particular motherboard seems to have issues powering up with some PSUs.
At least two out of five PSUs I have refused to power up. Others work perfectly fine, no voltage dropout or shorts.
Should I investigate further, or is it normal perhaps? (high 5v stb demand or low PGD delay, idk)
