Reply 40 of 42, by paradigital
- Oldbie
Unfortunately I’ve already replaced the TIM as explained on page 1.
Finally got around to replacing the caps using a mix of Panasonic and Rubycon caps, and so far everything seems good. I ended up having to re-install though due to (what I assume was) corruption of the OS after so many crashes.
Next job is changing the SLOT A fan as 1) it's a loud thing, and 2) it's flow rate is awfully low.
paradigital wrote on 2023-05-17, 12:14:Finally got around to replacing the caps using a mix of Panasonic and Rubycon caps, and so far everything seems good. I ended up having to re-install though due to (what I assume was) corruption of the OS after so many crashes.
Good to hear you got it working again! Now you can finally enjoy it! 😃
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
