Unstable Slot-A build.
Reply 40 of 42, by paradigital
Unfortunately I’ve already replaced the TIM as explained on page 1.
Reply 41 of 42, by paradigital
Finally got around to replacing the caps using a mix of Panasonic and Rubycon caps, and so far everything seems good. I ended up having to re-install though due to (what I assume was) corruption of the OS after so many crashes.
Next job is changing the SLOT A fan as 1) it's a loud thing, and 2) it's flow rate is awfully low.
Reply 42 of 42, by bloodem
paradigital wrote on 2023-05-17, 12:14:
Good to hear you got it working again! Now you can finally enjoy it! 😃
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
