First post, by waterbeesje
Hi!
My recent sortoff dumpster find: a Tyan S1856S Tomahawk BX.
This board is in need of a bios. Not just the software part, but also the chip itself. It's missing, never had it.
I can find the software easily here:
https://theretroweb.com/motherboards/s/tyan-s1856s#downloads
Now I just need the chip but I don't know what chip it needs. Is it some 28c128? Of 29c? Or which would work?
The manual doesn't state this.
By the way: I've got many other boards laying around which I can use as vehicle to flash the bios onto the new chip.
Thanks!
Stuck at 10MHz...
Reply 1 of 5, by bogdanpaulb
From this picture: https://www.google.com/search?q=Tyan+S1856S+T … =Zi1ykbCbbEPJZM it' should be a Winbond chip. Any 2 Mbit(256x8) flash ic in a dip32 package should work like: https://pdf1.alldatasheet.com/datasheet-pdf/v … 9F002UP12B.html, https://pdf1.alldatasheet.com/datasheet-pdf/v … 002NT-55JC.html or http://www.datasheet39.com/PDF/543905/F29C510 … -datasheet.html and there are many others. Check on your spare parts/defective boards, if you have any, for a similar ic. Mind the pinout/key !
Reply 2 of 5, by AmiSapphire
Yeah, original BIOS chip is a Winbond W29c020 IC. Theoretically, any 29C variant chip would work on this board.
https://pdf1.alldatasheet.com/datasheet-pdf/v … D/W29C020C.html
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 4 of 5, by waterbeesje
Thanks, i know which one I'm gonna search for now 😀
It would be a pity if this one would be recycled just because of the missing bios, it's a nice board indeed!
Stuck at 10MHz...
Reply 5 of 5, by Repo Man11
I was lucky enough to pick up a Tyan S1854 as part of a lot I purchased for $50.00. When it didn't POST, I took the BIOS chip out and reflashed it in my programmer and it worked fine - I guess maybe it had a bad BIOS flash and ended up being stowed away.
"A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it." - Jack Handey
