First post, by waterbeesje
Hi!
My recent sortoff dumpster find: a Tyan S1856S Tomahawk BX.
This board is in need of a bios. Not just the software part, but also the chip itself. It's missing, never had it.
I can find the software easily here:
https://theretroweb.com/motherboards/s/tyan-s1856s#downloads
Now I just need the chip but I don't know what chip it needs. Is it some 28c128? Of 29c? Or which would work?
The manual doesn't state this.
By the way: I've got many other boards laying around which I can use as vehicle to flash the bios onto the new chip.
Thanks!
Stuck at 10MHz...
Reply 1 of 9, by bogdanpaulb
From this picture: https://www.google.com/search?q=Tyan+S1856S+T … =Zi1ykbCbbEPJZM it' should be a Winbond chip. Any 2 Mbit(256x8) flash ic in a dip32 package should work like: https://pdf1.alldatasheet.com/datasheet-pdf/v … 9F002UP12B.html, https://pdf1.alldatasheet.com/datasheet-pdf/v … 002NT-55JC.html or http://www.datasheet39.com/PDF/543905/F29C510 … -datasheet.html and there are many others. Check on your spare parts/defective boards, if you have any, for a similar ic. Mind the pinout/key !
Reply 2 of 9, by AmiSapphire
Yeah, original BIOS chip is a Winbond W29c020 IC. Theoretically, any 29C variant chip would work on this board.
https://pdf1.alldatasheet.com/datasheet-pdf/v … D/W29C020C.html
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 3 of 9, by smtkr
I hope you get that working. I love Tyan motherboards.
Reply 4 of 9, by waterbeesje
Thanks, i know which one I'm gonna search for now 😀
It would be a pity if this one would be recycled just because of the missing bios, it's a nice board indeed!
Stuck at 10MHz...
Reply 5 of 9, by Repo Man11
I was lucky enough to pick up a Tyan S1854 as part of a lot I purchased for $50.00. When it didn't POST, I took the BIOS chip out and reflashed it in my programmer and it worked fine - I guess maybe it had a bad BIOS flash and ended up being stowed away.
Reply 6 of 9, by waterbeesje
Little update after a year.
The board has been laying in a box, stored away because of other projects.
I got a 29c020 chip and used uniflash om another board to hotflash the most recent bios. Uniflash succeeded, the other board sort of tried to boot with it (semi-success because of wrong bios for the board).
Placed the fresh-fladhed chip into the Tyan, put a celly 733 and some ram in (jumpers to celly 433), and turn it on.
Nothing.
Post card gives me ---- and ready signal status off.
I'm lost for now 🙁
Stuck at 10MHz...
Reply 7 of 9, by PC Hoarder Patrol
waterbeesje wrote on 2024-05-10, 22:20:
Little update after a year. The board has been laying in a box, stored away because of other projects. I got a 29c020 chip and u […]
Nothing.
I'm lost for now 🙁
Maybe PPGA only...Tyans cpu matrix shows no FC-PGA support for the board
Reply 8 of 9, by waterbeesje
Maybe, thats something to put on the list 😀
I think I have a 433 or 400 Mendocino in the box to try.
Just read the manual and it shows Celeron compatibility only, while theretroweb states it supports coppermine as well, so that's why I've put in the 733.
Yes I know the garbage collection from good old th99 still remains and we all are fixing and updating TRW and support may vary from board to board 😉
Stuck at 10MHz...
Reply 9 of 9, by waterbeesje
It's a workey!
I've put in the Mendocino 433 and it boots right to the CF card.
Mission accomplished!
Stuck at 10MHz...
