HP 240MB HDD Failure
First post, by LaC
I recently got this HP Vectra 486/66N (D2793A) pizza box PC.
Was working great for a week. Then on boot the bios would test drive C and say the controller had failed.
A reboot would usually fix it.
Now the bios complains every time. I tried hooking it up to my modern PC and the drive still won't read.
So guess I need to replace this 30+ year old drive. Sad.
Anway.
Trying to figure out what I actually need to get that the bios will support. The bios is V.04.04
This is the drive I have:
P/N is D1697A
Any help would be appreciated.
Reply 2 of 25, by LaC
douglar wrote on 2024-01-25, 13:45:
Sounds like the drive motor is having problems
possibly, it is pretty loud.
really want to keep things as period accurate as possible. I plan on just buying a new drive, but not sure what is compatible (outside of just replacing the drive with the same one).
Reply 3 of 25, by douglar
LaC wrote on 2024-01-25, 14:34:
Does your BIOS show a date at boot or on the config screens?
Reply 4 of 25, by pentiumspeed
That's quantum hard drive. ProDrive LPS 240. Fast hard drive for their time. 4,500 rpm. I had 120MB version once.
You can replace with anything, like using 270mb as 240MB using the same drive type number, same with 540MB as 504MB on different type number.
Cheers,
Great Northern aka Canada.
Reply 5 of 25, by konc
LaC wrote on 2024-01-25, 06:55:
How did you connect it to your modern PC? If it's with some USB -> IDE adapter, don't throw away the drive yet.
Reply 6 of 25, by LaC
douglar wrote on 2024-01-25, 15:00:
I think its 1993. Its and HP Vectra. Couldn't find any other info on the bios.
Reply 7 of 25, by LaC
pentiumspeed wrote on 2024-01-25, 16:54:
Cheers,
Just trying to figure out what the max size would be.
I think over 1GB is too much since these older bios's don't support LBA or something like that? Memory is fuzzy on that.
Reply 8 of 25, by LaC
konc wrote on 2024-01-25, 17:21:
Yes usb->ide adapter.
I'm sure the data is fine on the drive, but I suspect its the motor or something on the main board.
Reply 9 of 25, by douglar
LaC wrote on 2024-01-25, 18:08:
A 1993 BIOS is going to be limited to to a 512MB drive and CHS addressing. Just about any 512MB Hard drive, CF, SD adapter or 40 Pin DOM should work fine. You could even buy larger up to 2 GB and just configure it for 1023 cylinders, 16 heads, and 63 sectors per track and it should be fine. If you buy larger than 2 GB, it might work, but you start to run into some other issues. If you search ebay for "40pin DOM", you should see a lot of options for <$20. If you want to use more than 512MB, you would need to look into MRBIOS, XUB (XtIde Universal BIOS) or a drive overlay and I'd strongly recommend Win95b or newer for your OS.
Your Quantum ProDrive LPS is the same vintage and it is not likely that it supports LBA addressing.
If your USB to PATA device was built after 2010, it is quite likely that it only supports LBA addressing.
So with those things in mind, it seems pretty unlikely than your Quantum ProDrive LPS is going to work with your USB adapter (unless your USB adapter is more than 15 years old).
I have the same drive in my basement. I could test it out for you if you like.
Your drive jumper settings are in this doc: https://www.seagate.com/files/staticfiles/max … ive_jumpers.pdf
Here are some larger posts that I wrote for people in the past two days:
Re: 486 PC Hard Drive Troubles
Re: HDD won't boot on 486
Reply 10 of 25, by b0by007
I have a similar model D2753A - HP Vectra 486/25N , with the same bios.
I installed one mechancal drive 1.2 gb and a 4 gb CF card and it works great.
Edit: mine had the same drive, which died too.
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 11 of 25, by LaC
b0by007 wrote on 2024-01-25, 19:12:
Interesting. Are they formatted at that size? Didn't think the bios could handle it.
Reply 12 of 25, by b0by007
Yes. The 1.2 gb mechanical hdd is formated all 1.2 gb fat 16 partition.
The CF card is split in 2 gb and 1.7 gb fat16 partitions.
I use ms dos 6.22
Reply 13 of 25, by douglar
b0by007 wrote on 2024-01-25, 20:17:
I use ms dos 6.22
Did you add a hard drive controller with an option ROM or is there a drive overlay installed?
Reply 14 of 25, by b0by007
No addon controller or drive overlay. The bios just detects and uses full hdd up to 4gb.
Reply 15 of 25, by PC Hoarder Patrol
LaC wrote on 2024-01-25, 19:52:
Latest BIOS is v.04.09 (attached ) - adds support for P24T OverDrive processors (v.04.04 was the original shipping / release version)
vbb1z1us.exe
291.8 KiB
11 downloads
Reply 16 of 25, by Sudos
I wouldn't bother trying to resurrect the drive, assume it has failed. Prodrives are notorious for having rubber head bumpstops. It's likely it hit it and got stuck. Goopy mess, can be replaced with some heat shrink if you're quick about it and the platters didn't get any on them however.
Reply 17 of 25, by douglar
b0by007 wrote on 2024-01-25, 21:40:
It looks like you might have a newer Bios version than the original poster. Bios with support for P24t processors didnt come out until Q4 1995.
Reply 18 of 25, by LaC
Sudos wrote on 2024-01-25, 23:22:
its still spinning. you can hear the head try to read when it boots up per normal. It's just loud.
Reply 19 of 25, by LaC
That's awesome. How do you update the bios? Just run the exe via command prompt?
Whats the model of the drive?
