HDD won't boot on 486
First post, by d00mo
Hi friends!
I am in the process of building a 486, and have ran into an issue with the HDD, and are hoping for some help from the experts 😀
The HDD is a 4 GB Western Digital (E-IDE).
If I connect the drive to a Pentium build, it works just fine. I am able too boot and run the drive with no issues.
The following settings are then auto-detected in BIOS:
CYLS: 1023
HEAD: 128
PRECOMP: 0
LANDZ: 8183
SECTOR: 63
MODE: LBA
The attachment thumbnail_IMG_2664.jpg is no longer available
If I connect the drive to my 486, the startup tests pass, but boot fails with the following message:
Disk I/O error
Replace the disk, and then press any key
The attachment thumbnail_IMG_2668.jpg is no longer available
The drive is detected as only 2 GB and with different settings:
CYLS: 8184
HEADS: 16
PRECOMP: 65535
LANDZONE: 8183
SECTORS: 63
The attachment thumbnail_IMG_2667.jpg is no longer available
So SIZE, CYL, HEADS and PRECOMP differs. MODE is not available, making me think that LBA is not supported by the MOBO and/or Controller.
For the failing 486 build, I am using the following:
MOBO: FIC 486-GVT-2
VLB Controller: VSAB-666 Multi I/O / IDE
Any thoughts on why it is failing? Incorrect settings? Compability issues?
Should the drive the operational eventhough only detected as 2 GB?
Reply 1 of 9, by Horun
Need to know the WD HD model number. Need to know the BIOS version of the Fic 486-GVT-2
The current bios does not support greater than 2GB HD and cannot properly ID the C/H/S.
Reply 2 of 9, by douglar
The date of your motherboard bios would be handy too.
What version of Dos are you booting? Dos before win95 osr2 does not work woth cylinders > 1023
Here’s some notes that I typed up esrñier today
Re: 486 PC Hard Drive Troubles
Reply 3 of 9, by d00mo
Horun wrote on 2024-01-25, 03:43:
WD HD model number is AC14200-30RT
The attachment thumbnail_IMG_2673.jpg is no longer available
BIOS version is 4.50
The attachment thumbnail_IMG_2669.jpg is no longer available
Something that confuses me is that the failing 486 actually identifies C/H/S correctly (as shown on the drive, see picture), except for 2GB instead of 4 GB.
But in the working Pentium, C/H/S is identified as something else (1023/128/63), but is working anyway...
Reply 4 of 9, by douglar
Bios older than July 1994 often let you enter larger values into the drive table, but internally the BIOS INT13 call rarely was able to process values larger than 1023 Cylinders , 16 Heads, 63 Sectors/Track, which is 512MB.
Your drive is 4 GB, so you likely need a BIOS INT handler newer than May 1996 to support that size.
Here are three common ways to do that:
  • on a 486, there's a reasonably chance you can find an MR Bios v1.65 or newer that understands your 4GB drive if you enable cylinder translation. You would make a new EPROM and swap out the socketed chip on your motherboard.
  • Make an option rom like XUB (xtide universal bios), put it on an isa add-in board and you get LBA28 and LBA48 support
  • Set your drive to as smaller geometry, boot off floppy and install a drive overlay like Easy drive 9.09w and get LBA28 support.
Reply 5 of 9, by d00mo
douglar wrote on 2024-01-25, 11:14:
Bios older than July 1994 often let you enter larger values into the drive table, but internally the BIOS INT13 call rarely was […]
Alright, many thanks for that detailed explanation!
Reply 6 of 9, by Disruptor
d00mo wrote on 2024-01-25, 06:57:
WD HD model number is AC14200-30RT thumbnail_IMG_2673.jpg […]
Yes, that BIOS looks ugly.
It may have a border at 1 or 2 GB.
You probably may enter values below that border and use the disk with reduced size. Perhaps a DDO may help then... (3rd suggestion from doglar)
Reply 7 of 9, by d00mo
A follow up on this… I went ahead with the suggested option of using ez-drive and it works like a charm!
Down the road I used a CF card as well and both options now works perfectly!
My first retro build is now completed and it was extremely fun putting it together.
This site really is a wealth of information 🤗
Attaching a picture of the beauty 🤩
The attachment IMG_2739.jpeg is no longer available
Reply 8 of 9, by zwrr
If you have an ISA network card installed, you can install the XTIDE Universal BIOS ROM chip on it, or make a standalone ISA 8bit mini card for it, except for the disadvantage that it will occupy an ISA slot, it is perfect.
I made a standalone card with a 64GB HDD on the 386 and 486, Everything was perfect.
SBC1: Cyrix 5x86-120, HS-5x86HVGA, 16MB EDO, GD54M30, SB Pro II, HardMPU-wt
SBC2: VIA C3-800, PCISA-C800, 128MB SDRAM, Savage4 Pro, SB AWE64 Gold
SBC3: Tualatin-S 1.4G, PCI-6872, 256MB SDRAM, FX5200 PCI, Voodoo2 SLI, SB Live
Reply 9 of 9, by d00mo
zwrr wrote on 2024-02-20, 08:00:
I read about it and would be fun to try out that road also!
Maybe next project… 😀
