First post, by Stojke
Do these make good Socket 462 coolers?
I found two with 7000RPM fans, new unpacked.
Reply 1 of 4, by 5u3
No, they don't perform nearly as well as their looks, weight and noise suggests. You may be interested in Dan's massive CPU cooler comparison. 😉
Reply 2 of 4, by sliderider
Just a point to remember when buying a CPU cooler, for a given surface area pure copper is better at conducting heat than aluminum or part aluminum-part copper. It's also usually more expensive.
Reply 3 of 4, by cdoublejj
from what i can tell and have experienced aluminum copper combination works the best. copper conducts heat better than aluminum but, aluminum dissipates heat better than copper. Because copper conducts heat better it like to hold on to it or conducts it at such rate that aluminum dissipates better but, aluminum probably dissipates better because it doesn't conduct as well.
Or you can throw all that out the window and wait for graphene heat sinks. graphene thermal paste already exists.
http://www.youtube.com/watch?v=R5dwdZCKBZM
Reply 4 of 4, by Stojke
Dans guide wont load 😒
I view the video, and i found some thermal take coolers as well.
Dont know, orbs look pretty cool 😁
