First post, by Terelyn
This happens during the intro when starting a new game. Sometimes it works as intended, but most often the intro crashes the game. There is also an other issue where the game loads up at a lower resolution at 4:3 aspect ratio and streched. It rarely happens and reloading a save file or traveling to an other area/location seems to fix the issue.
I have only enabled vsync, otherwise i'm using the default config. The latter is probably an issue with game itself as i didn't touch the resolution options of dgVoodoo.
