First post, by Terelyn
This happens during the intro when starting a new game. Sometimes it works as intended, but most often the intro crashes the game. There is also an other issue where the game loads up at a lower resolution at 4:3 aspect ratio and streched. It rarely happens and reloading a save file or traveling to an other area/location seems to fix the issue.
I have only enabled vsync, otherwise i'm using the default config. The latter is probably an issue with game itself as i didn't touch the resolution options of dgVoodoo.
Reply 1 of 2, by Terelyn
I have tried it with the latest version of dgvoodoo (v2.83.2). The game isn't crashing anymore, but now there is only a black screen when a video is playing.
Reply 2 of 2, by Dege
It crashes for me. dgVoodoo is not compatible with this game. When doing a screenmode change, then extra window messages are generated from DXGI (compared to native DX8) and the game tries to recursively do additional rendering from the message handler.
I'm afraid I cannot "fix" it now, patching the game not to do that would be better idea anyway.
