First post, by legluondunet
Hello,
I tried to launch Moto Racer with DGVoodoo2.
But when I launched it I have the error message: "Moto Racer needs 16 bits screen mode".
Is it possible to force 16 bits screen mode for a game with DGVoodoo?
Thank you for your help.
Reply 1 of 17, by mrau
the app is probably checking your desktop mode
Reply 2 of 17, by legluondunet
Surely. Some old games can launch only in 16 bits screen mode like Moto Racer 1 and 2. Is it possible to bypass this with DGVoodoo2?
Reply 3 of 17, by teleguy
Did you try Windows compatibility settings? On Windows 10 the option is called Reduced Color Mode.
You can select 8 or 16 bit but on Windows 7 and prior it might only be 8 bit IIRC. The Compatibility Toolkit could possibly help in this case.
Reply 4 of 17, by legluondunet
I play games on Linux with Wine, I can not do that and dgVoodoo2 does not have this feature. I finally found another wrapper that can simulate a 16b desktop for the game and it is compatible with Linux Wine: DxWnd. I wrote Lutris script for people to install this games and others easier, you could consult my scripts list here:
https://www.gamingonlinux.com/index.php?modul … _id=3867&page=1
Some of them use dgVoodoo2.
Reply 5 of 17, by VirtuaIceMan
Right-click the shortcut for the game, click Compatibility and choose Reduced clour mode: 16bit.
Personally though, I use a ripped version of the GOG release, where they fixed a great deal. I actually bought the Moto Racer Collection pack from anuman.fr, who had the official license at that time, but it was heavily bugged. From reading the Steam comments, that version isn't as fixed as GOG's either!
However if you have the original CD version, then that's probably okay!
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 6 of 17, by rasz_pl
OP mentioned Linux+Wine 😀
I wonder where did the "I need desktop at X bit depth" come from? Afair even some fullscreen games required specific 8/16 bit depth. This seems crazy.
Reply 7 of 17, by teleguy
There's a DesktopBitDepth property in the dgvoodoo.conf now.
Reply 8 of 17, by legluondunet
Just tested the last WIP dgVoodoo2 version, changed this option:
DesktopBitDepth = 16
launched Moto Racer, I still have this message:"16 bit screen mode required!".
Someone tested this new dgVoodoo2 feature and obtained better result with this game??
Reply 9 of 17, by Dege
This game may query the screen bit depth not through ddraw (so that, dgVoodoo) but plain GDI API which is unaffected by dgVoodoo.
I wanted to write to set 'Reduced colors' to 16bit in the compatibility options for the game which works nicely on win10 but as I can see you run the game on linux(?).
I think it were less complicated to patch the game by cutting out the part checking for the color bit depth.
Reply 10 of 17, by teleguy
The game is currently on sale for ~1€ on GOG so I took a look at the exe. It uses GDI to access the desktop resolution but I couldn't find anything for the color depth there.
So I downloaded the newest WIP and was able to get into the game just fine (should probably have tried that first 🤣 ), but there are a lot of glitches and Direct3D mode doesn't work. The 16 bit error message shows up after exiting the game though.
Reply 12 of 17, by Dege
My experiences with this game (not the GOG version):
Launch the game with the following parameters:
moto.exe -d3d -TextureVideoMem268435456 -zbuffer -frameratemax=60 -CorrectRatioTextures
- If desktop bitdepth is not 16 then the game just silently crashes at startup (I guess it wants to invoke some error dialog but my installation is somewhat corrupt and no resource strings are found)
- If I set DesktopBitDepth to 16 in dgVoodoo.conf then the game starts but pops up the '16 bit needed' error dialog while entering the game menu (probably queried through GDI)
- If I also set 16 bit display mode amongst app compat options then it works (this option is enough in itself, no need to set in dgvoodoo.conf too)
- One additional problem: you need to use a virtual card that has NO paletted texture support (ATI, Matrox) otherwise no D3D mode is available in ingame race
Reply 13 of 17, by teleguy
There's a game launcher included that already applies most of these parameters.
Direct3d works after selecting a different videocard but the game looks even more broken than before, the 3D screen is almost completely white. However this can be fixed for some reason by switching to 16/9 mode. Then only the distant background is a white wall, similar to software mode. The 3D model of the bike within the menus is still mostly white.
The DesktopBitDepth setting is enough to bypass the error message for me, though it shows up on exit. Maybe the GOG staff made some changes.
There's no message at all when using Reduced Color mode.
Reply 14 of 17, by Gagster
Moto Racer 1 works fine with dgVoodoo2 on my PC (GoG-version).
I'm using dgVoodoo 2.52 on Moto Racer 1, on dgVoodooSetup file under DirectX, ATI Radeon 8500 as video card, VRAM 128mb, I personally use 1280x960@60hz resolution (I have a 1080p monitor), AntiAliasing 8x. Under the General Tab in dgVoodooSetup under Appearance I have Selected Full Screen and Enumerate Refresh Rate.
I start Moto Racer 1 by launching MotoRacerLauncher.exe. Z-Buffer and DirectX 3D are on, and No Alpha Blending and Manual Settings off. Thereby I press the "3. 2. 1. GO!" button on the bottom to successfully launch the game on Windows 10 64 bit.
I don't have any compatibility options selected in Windows 10 on any of the *.exe files in the Moto Racer 1 folder.
If I click on the Manual Settings in MotoRacerLauncher.exe, This text is displayed: -DoRealLock -OpaqueBlackLevel3 -TextureSquareOnly -Pal16 -CorrectRatioTextures -NoDither -TextureVideoMem268435456 -FrameRateMax59
CPU: i7-12700KF
RAM: 64 GB
GPU: GeForce GTX 1080 Ti
OS: Windows 11
Reply 15 of 17, by teleguy
Yep, 2.52 works flawlessly.
Tried switching to "D3DCompiler only" in WIP60_1 but it didn't help.
Edit:
Doesn't launch for me without 16 bit compat mode.
Reply 16 of 17, by legluondunet
whatever the version or renderer mode you use, do you obtain better results than the joined captures screen?
D3D mode filter on
Reply 17 of 17, by teleguy
I don't think so.
Edit:
