First post, by Mud
Mobil1 Rally Championship 2000 work very well with dgVoodoo but to perfection its need FSP limiter
Too many fps causing bug in this game and making sound desynchronization.
I dont saw in dgVoodoo option to select frame rates
Maybe someone have solve to this issue?
Reply 1 of 3, by FulValBot
You have to force a 60hz refresh rate in dgVoodoo2
in directx where you see unforced add ", 60hz" without quotes (remember to enable "Enumerate refresh rates" in General); this will fix also some crashes in some tracks; if necessary use a cap to 30 fps with nvidia or amd (your card) driver
remember also to enable v-sync in-game (or in dgVoodoo2 if is not included in-game)
some sounds bug can be fixed only with 1 core
