Recent WinXP/POS2009 update causes errors with PIII systems
Getting old software/games running on older hardware.
Re: Recent WinXP/POS2009 update causes errors with PIII systems
Postby nd22 » 2019-2-20 @ 16:53
I just installed the February updates on my Athlon XP 3200 and I can report the following:
4486474: OK - the update for IE8 installs always regardless of the presence of SSE1/2/3 or not!
4486463: OK
4486464: FAILED
4486465: OK
4486924: OK
4487085: FAILED V2 - you should not installed V1 even if your CPU supports SSE2 instruction set!
4487086: OK
4487385: OK
4487396: OK
4462154: OK
4486485: OK
4483495: OK
4483475: OK
We are now on 2 months of support left!
Please note that all updates for Office 2007 compatibility pack are not tested because I do not use it!
nd22
Postby nd22 » 2019-3-04 @ 09:44
For those with single core CPU the update 4886463 is being offered again and again no matter how many times is installed. It is strongly recommended to hide the update as there is no consequence for single core systems even those with hyper-threaded CPU!
nd22
Postby nd22 » 2019-4-02 @ 17:15
After 1 month I finally got to install the March updates on my Athlon XP 3200. Here are my results:
4489873: OK
4486468: OK
4486536: OK
4486538: OK
4487989: OK
4489493: OK
4489973: OK
4489974: OK
4489977: OK
4490228: OK
4490385: FAILED
4490500: OK
4490501: OK
4493341: OK
All but 1 installed just fine - the system is as responsive as before.
We are now on the final month of support! :depressed:
nd22
Postby Clardake » 2019-4-02 @ 19:49
Thank you so much for your reports, nd22 :happy:
While it's a shame some recent updates for Windows Embedded/POSReady 2009 require SSE2 instructions set, it's fine most recent updates still don't require it.
nd22 wrote:We are now on the final month of support!
There could be some updates in the next month. The support of Embedded Standard 2009 ended in January but the February updates are still intended for it (according to Windows Update). In May 2014, Microsoft released an update for Internet Explorer on Windows XP, while its support ended in April 2014. Some updates came out for NT 4.0 Server in early 2005, while its support ended in 2004, etc.
Clardake
Postby nd22 » 2019-4-13 @ 03:21
I installed last night the final batch of updates and I can report the following:
4493435: OK
4487990: OK
4491443: OK
4493563: OK
4493790: OK
4493793: OK
4493794: OK
4493795: OK
4493796: OK
4493797: OK
4493927: OK
4494059: OK
4494528: DESTROYS INSTALLATION ROUTINE
4495022: FAILED
These are the last updates for Windows XP all versions ever! Now it is the time to start some kind of backup of all systems running XP or disconnecting them form the internet. Starting form July 2019 Microsoft will use SHA2 in all Windows updates - I do not know if Windows update version 6 will continue working or starting from July will fail as version 4 for Windows 9X did. I will try to do an archive with all Windows XP POS2009 updates from April 2014 to April 2019.
nd22
Postby feipoa » 2019-4-13 @ 03:31
I guess I better update all my SSE sytems soon! I was waiting for April updates to be released. Will Office and other MS updates continue?
nd22 wrote:I will try to do an archive with all Windows XP POS2009 updates from April 2014 to April 2019.
With an installer program?
User avatar
feipoa
Postby nd22 » 2019-4-15 @ 10:16
The problem is I starting my archive in August 2018. So I got absolutely no updates before that date. If someone has and is willing to share it I will greatly appreciate it. I will try to write a small installer program with SSE1-only updates but I must have all updates from April 2014 to April 2019.
nd22
Postby marvias » 2019-4-15 @ 17:51
How I got this: I installed XP with SP3 from clean MS iso, updated registry with PosReady tweak and installed: KB898461, windowsupdateagent-3.0, and KB892130. After this both auto updades and Windows update web started working.
Here is list of XP Embedded updates only (it showed also many post-sp3):
Code: Select all
KB2926765
KB2957503
KB2993254
KB2993651
KB2998579
KB3004361
KB3013126
KB3020393
KB3021674
KB3029944
KB3033889
KB3033890
KB3035132
KB3065979
KB3078601
KB3081320
KB3087039
KB3092601
KB3109560
KB3121918
KB3124275
KB3124624
KB3126587
KB3126593
KB3139914
KB3140709
KB3145739
KB3149090
KB3161561
KB3161949
KB3170455
KB3178034
KB3183431
KB3185911
KB3196718
KB3198510
KB4012583
KB4012584
KB4014652
KB4014794
KB4015383
KB4022747
KB4024323
KB4025218
KB4025409
KB4025497
KB4026061
KB4034775
KB4039384
KB4041995
KB4047211
KB4052303
KB4056564
KB4056941
KB4089082
KB4089175
KB4089453
KB4089694
KB4091756
KB4101477
KB4130957
KB4291391
KB4294413
KB4343674 -SSE2
KB4457163
KB4458000 -SSE2, previous KB4042121
KB4458001
KB4458006
KB4458318
KB4462935
KB4462987 -SSE2
KB4463103
KB4463573
KB4467689
KB4468323
KB4470118
KB4473077 -SSE2, previous 2018-10-KB4463361 reported here as ok, otherwise KB4042121
KB4486463
KB4486465
KB4486468
KB4486536
KB4486538
KB4486924
KB4487085 -SSE2
KB4487086
KB4487989
KB4487990
KB4489493
KB4489973
KB4489974
KB4489977
KB4490228
KB4490385 -SSE2
KB4490501
KB4491443
KB4493341
KB4493563
KB4493790
KB4493793
KB4493794
KB4493795
KB4493796
KB4493797
KB4493927
KB4494059
KB4494528 -SSE2?, win installer error, fix using regsvr32 MSI.DLL, chain of previous: (ok)2018-03-KB4087398 (sse2)2018-08-KB4340937 (sse2)2019-02-KB4486464
KB4495022 -SSE2
ie6 cumulative KB3124275
ie8 KB2510531 + cumulative KB4493435
WMP11 KB3067903 + KB3033890
I didnt test yet if it installs fine on non-SSE2 HW, information regarding SSE2 is taken from this thread + I noted previous updates which could be installed instead of the problematic ones, if there are any.
Updates can be downloaded manually here https://www.catalog.update.microsoft.com/Home.aspx
Let me know if I have incorrect information on SSE2 marks in the list, I will update it.
marvias
Postby Clardake » 2019-5-15 @ 19:07
nd22 wrote:I installed last night the final batch of updates and I can report the following(...)
Did you try to fix the issue by re-register some DLLs ?
Code: Select all
regsvr32 MSI.DLL
regsvr32 MSIHND.DLL
regsvr32 MSISIP.DLL
Source: https://msfn.org/board/topic/171814-pos ... nt-1162203
Maybe they'll shortly release a KB4494528-v2, as the end of support shouldn't mean release a such flawed update.
nd22 wrote:These are the last updates for Windows XP all versions ever!
Wrong! Just a month after the end of POSReady support, Microsoft released another patch, intended for any version of XP SP3 : https://support.microsoft.com/en-us/hel ... -kb4500331
Is that hotfix (fully) compatible with non-SSE2 processors? I don't know how exactly you define the processor compatibility with your Athlon XP, but I guess you'll test that patch soon :cool:.
Clardake
Previous
Return to Software
Who is online
