Reply 60 of 85, by nd22
- Oldbie
I just installed the February updates on my Athlon XP 3200 and I can report the following:
4486474: OK - the update for IE8 installs always regardless of the presence of SSE1/2/3 or not!
4486463: OK
4486464: FAILED
4486465: OK
4486924: OK
4487085: FAILED V2 - you should not installed V1 even if your CPU supports SSE2 instruction set!
4487086: OK
4487385: OK
4487396: OK
4462154: OK
4486485: OK
4483495: OK
4483475: OK
We are now on 2 months of support left!
Please note that all updates for Office 2007 compatibility pack are not tested because I do not use it!
