First post, by stelth
When i try to setup my DOS game Music Audio (Duke Nukem 3D for example) it says " FM Chip not detected", but in Doom 95 the music works fine,what can i do?
Reply 1 of 7, by jheronimus
If I’m not mistaken, Doom 95 is a Win95 port that uses DirectSound and does not actually access your sound card directly. Unlike Duke Nukem which is a proper DOS game.
What are your specs? What is your soundcard? Have you installed the DOS drivers for it? What resources does it use? Have you tried to run the test (e.g. diagnose.exe for Sound Blaster)?
MR BIOS catalog
Unicore catalog
Reply 2 of 7, by stelth
The laptop is a Toshiba Tecra 730X CDT.
https://usermanual.com/document/7508/toshiba- … cification.html
Reply 3 of 7, by leileilol
IIRC that Tecra used a CS4232 which is Windows Sound System compatible (and has a YMF262), so try the WSS sound options while running Windows?
(Manual's showing up blank fyi)
Reply 4 of 7, by stelth
where are the wss options? do i need dos drivers for it?
btw the sound blaster works for the sound but not for the music, theres something that needs to be set up, i see that my sound card supports also the sound blaster pro,today ill try it and see what happens.
Reply 5 of 7, by stelth
stelth wrote:
When i try to setup my DOS game Music Audio (Duke Nukem 3D for example) it says " FM Chip not detected", but in Doom 95 the musi […]
any tips?
Reply 6 of 7, by MAZter
Perfect ISA soundcard, in theory
    cwd_dos.zip
    887.81 KiB
    71 downloads
    README.TXT
    2.1 KiB
    82 downloads
