First post, by rick12373
- Member
On my 486 running DOS 6.22 for some reason I have to use SB16SET in the AUTOEXEC.BAT to set the volume levels all the way to max. If I don't do this my speakers are too quiet (have tried multiple speakers). In order to use SB16ET I have to load CTSB16.SYS and CTMMSYS.SYS in the CONFIG.SYS. When I load CTSB16.SYS and CTMMSYS.SYS my conventional memory goes down to below 600K (depending on what options I choose from Phils's menu at boot, but it will always go down as far as I know). I am using Phil's AUTOEXEC.BAT and CONFIG.SYS files from his web site and I put the CTSB16.SYS and CTMMSYS.SYS in the section named [COMMON].
Is between 549K to 582K of conventional memory enough for games? Is there a better way to load the CTSB16.SYS and CTMMSYS.SYS in the CONFIG.SYS so that it doesn't use so much conventional memory?
This is my AUTOEXEC.BAT:
@ECHO OFF
PROMPT $p$g
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D1 H5 P330 T6
SET MIDI=SYNTH:1 MAP:E
C:\SB16\DIAGNOSE /S
C:\SB16\SB16SET /SP:70 /MA:255 /VO:255 /MI:255
PATH C:\WINDOWS;C:\DOS
PATH C:\NC;%PATH%
SET TEMP=C:\DOS
GoTo %config%
:EMC
:XMC
:CMC
LH C:\DOS\MSCDEX.EXE /D:OPTICAL
:EM
:XM
:CM
LH C:\DRIVERS\CTMOUSE.EXE /R2
:E
: X
:C
And this is my CONFIG.SYS:
[COMMON]
FILES=40
DOS=HIGH,UMB
REM ** FILES=30
BUFFERS=30
LASTDRIVE=H
REM THE FOLLOWING 2 LINES ARE NEEDED TO SET SB16 TO MAX (TOO QUIET OTHERWISE)
DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5
DEVICE=C:\SB16\DRV\CTMMSYS.SYS
[menu]
menuitem=EMC, Expanded memory + Mouse + CD-ROM
menuitem=XMC, Extended memory + Mouse + CD-ROM
menuitem=CMC, Conventional Memory only + Mouse + CD-ROM
menuitem=EM, Expanded memory + Mouse
menuitem=XM, Extended memory + Mouse
menuitem=CM, Conventional memory only + Mouse
menuitem=E, Expanded memory
menuitem=X, Extended memory
menuitem=C, Conventional memory only
menudefault=EMC,10
[EMC]
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[XMC]
[CMC]
[EM]
[XM]
[CM]
[E]
[X]
[C]
DEVICE=C:\WINDOWS\SMARTDRV.EXE /DOUBLE_BUFFER
STACKS=9,256
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
