First post, by MRVFONE
Hello All,
I'm trying to find the DOS PCMCIA card and socket service software. I had downloaded heaps of "cardsoft.zip" files. But they won't work with the "Texas Instruments PCI-1420" PCMCIA chipset my laptop has.
I thought the card soft software was free to use for the DOS version... But can't seam to find a "full" version of it. Most seam to ONLY have the drivers for the chipset in a specific laptop etc.. Not a "full" install that has all of its drivers.
Any help would be apricated!
Thanks,
Tim.
Reply 2 of 14, by cyclone3d
I have a "full" version that came with a pcmcia sound card.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 14, by BitWrangler
I remember finding drivers for the TI stuff actually on TI's site some long while ago, 10+ years. Dunno if you could dig it out on the waybackmachine.
Reply 5 of 14, by cyclone3d
MRVFONE wrote on 2021-10-05, 08:00:
Did you want to share it?? […]
cyclone3d wrote on 2021-10-05, 01:52:
Thanks,
T.
Yeah, I'll image and upload the disks to vogonsdrivers hopefully this evening and then post back here with the link.
I might have a few other versions of cardsoft as well. I'll check at the same time. Maybe make a collection and upload them to vogonsdrivers and archive.org.
YMF7x4 Guide
Reply 6 of 14, by MRVFONE
cyclone3d wrote on 2021-10-05, 14:56:
Thanks,
T.
Thanks so much!! Its been driving me nuts, I just don't know why it is so hard to find the software...
Tim.
Reply 7 of 14, by lolo799
MRVFONE wrote on 2021-10-04, 21:37:
Hello All, […]
Hello All,
Thanks,
Tim.
Did you edit config.sys to add the drivers yourself?
That chip may be compatible with the ss365sl.exe or ss365lp.exe drivers.
Reply 8 of 14, by MRVFONE
lolo799 wrote on 2021-10-05, 22:01:
Hello All, […]
Hello All,
Thanks,
Tim.
Sadly its not compatible. I tried both files.. neigher worked 🙁
T.
Reply 9 of 14, by lolo799
What laptop model? Any Pcmcia related option in the Bios?
Try using sscbti.sys and cs.exe from Cardsoft/32 https://www.driverguide.com/driver/detail.php … driverid=576348
If that fails, use Cardware 7.0 from APSoft, there is a trial version available.
https://www.tssc.de/
Reply 11 of 14, by Bondi
Did you try Phoenix Card Manager? I think it worked at least with some TI controllers. Not sure about 1420, though.
PCM4.zip
2.98 MiB
256 downloads
Edit: and here is a "full install" of cardsoft Re: Compaq LTE Elite 4/50cx - how to get PCMCIA=> CF support?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 12 of 14, by MRVFONE
lolo799 wrote on 2021-10-06, 21:04:
What laptop model? Any Pcmcia related option in the Bios? Try using sscbti.sys and cs.exe from Cardsoft/32 https://www.drivergui […]
Tryed "sscbti.sys". But doesn't work with my TI chip onboard.... BUT this software actually came up with more options for support than any other drivers i have tryed. So i think it would help others that have a diffrent chipset than mine...
"Cardware 7.0 from APSoft", Apears to need windows 3.11 at a guess. It won't install in plain DOS.
T.
Reply 14 of 14, by lolo799
MRVFONE wrote on 2021-10-07, 21:26:
The cwdw.exe downloadable from their website is a Windows 32bit app that gives the choice of creating install floppies or unpacking in a directory, in it there's a DOS install.exe and a Win 3.1x setup.
