First post, by RetroVixen2K
- Newbie
so I decided that since my dad died last spring and given the retro cluster**** he left me in his will and that I should go ahead and finally tackle that retro arcade project(s). you know cause a mid life crisis is a great time to work on a project I've procrastinated on for the past 20 years. however there has been a major and I mean major set of set backs. the 90s family AT socket 7 machine was not only dead but the kamekazi power supply took out the hard drives too and I'm ordering parts to try to fix it myself but.... there are no grantees and I already had my primary plan in motion with a bit of an upgrade as that socket 7 was an abomination against the machine gods cobbled together with anything my dad could find. obscure intel board, AMD K6II+ that had no business being in it despite it matching speed. socket 3 heatsink begrudgingly reused in the dead of night, an uninterruptible power supply that had the battery pack hastily removed. home server tower case, two CD-ROMs as you never knew which one would work at any given time. an AWE64 that was neither value nor gold. that computer was held together with hardware store screws and cussing. oh and it gave me literal night terrors about tech problems. a simple K7 should be far less of an issue right? right. everything is working flawlessly on the hardware end of the active replacement machine. I even managed to hack the FreeDOS USB full version to work as a live CD by hybridizing install files.
so here is the rub. with those original hard drives dead I can't figure out how he got it to go to a halt screen on start up. lie it would stop and you'd see
select OS:
1.windows 95
2. windows NT
3. DOS
you'd press a number and if it was DOS it would take you to a new screen and ask you if you wanted
1. games
2.command line
3. tools
4.reboot
if you selected games it would give you several screens with 7 options and back and fourth navigation as well as sub folders. like say for instance commander keen was its own folder.
now that being said I've tried googling it every way possible to make a search query, I've tralled through his extensive library of reference encyclopedias til my eyes are defocusing and my left eye literally starts twitching.
I may have only just created my first account on here but you all have been extremely helpful as google tends to send me here and you've got discussions on exact issues I'm having and have already solved them.
so I gotta ask how did he do it, how can I then replicate it? and its gotta be easy enough to navigate like my dad had his rig so that its not daunting for my wife just to boot up a random game while I'm asleep.
we are working with a slot A board, RAID card with FreeDOS set on the card's boot disk and the main system board has a Primary disk with windows 2000 pro. I wanna load up DOS with the DOS games and have windows 2k provide the boot manager selection screen if I can help it.
fair warning I'm a hardware girl, I fix stuff, refurbish it, I put it together and make it play nice. I am not a programmer by any means. my dad was the programmer. I apologize if I sound like an idiot but I'm severely out of my element. I had hoped it would have been as simple as a wander through his files scraping relevant code and writing it in windows to drop into DOS .ini files or something like working with rainmeter but alas that cursed K6 got the last laugh on me. you might need to explain stuff to me in the simplest of ways. I'm new to programming anything let alone freeDOS and making boot menus. full disclosure: I'm using entirely period accurate hardware for the simple reason virtualization and emulation legit overwhelms me until I wind up crying from not being able to live up to my dad's legacy. then again he used to tell me how amazed and proud he was of my skill with hardware.
not that hardware can help me now. sadly in retrospect I think I won that argument. he used to argue that I was doing so much better than him with builds and making extreme workload capacity workstation/gaming rig combos he didn't believe possible without a server rack and severe latency that would rule out gaming. I argued my accomplishments don't amount to a hill of discarded silicon wafers if I can't program like him. sometimes being right hurts far more than being wrong ever could.
I know enough that the boot menu thingy has to be set up on the 2k side as DOS can't see large drives and NTFS. so I've configured the hardware accordingly so DOS is seen as a secondary preference. I've tested the boot from the RAID card to make sure it works. needless to say DOS is booting flawlessly with mirrored protection.
yes I did already check the advanced start up options, its not seeing FreeDOS because the stupid DOS installer forced me to have the windows drive disconnected as it was insisting on an overwrite on the wrong drive and I can't see anywhere to add an OS. I'm gonna try reinstalling win2k after I use it to drop the game files onto the DOS drive. if that doesn't do the trick I will let you know so I'd say focus mainly on the DOS menus question until I come back with a success or failure on the reinstall.
UPDATE: reinstall did not work. so if you know how to make the current windows install see the other OS I'm all ears.
"Okay. Look. We both said a lot of things that you're going to regret. But I think we can put our differences behind us. For science. You monster." ~ GlaDOS
