First post, by ColdBrain
I want to create a batch menu for the GOG version of Blood, for use with D-Fend Reloaded. I'll point the batch file to either of the game executables (BLOOD.EXE and CRYPTIC.EXE). But I want to add some bells and whistles to it, like a box around the text. Is there a tutorial for it? I found one, but it requires me to have DOS files and I don't have DOS installed.
Thanks in advance.
Reply 1 of 8, by leileilol
There was a very old (1987) program that would do exactly this, to generate an ASCII box with a menu system for batch file editing afterward. Forget what it was called though, might've had a stupidly simple name like 'makemenu' or something.
long live PCem
Reply 2 of 8, by zirkoni
Something like this?
@echo off
:start
cls
echo ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
echo º Menu º
echo ÌÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ͹
echo º 1. Blood º
echo º 2. Cryptic Passage º
echo º 3.+ MODS º
echo º 4.+ Multiplayer º
echo º 5.+ Editors º
echo º 6. Setup º
echo º 7. DOS Prompt º
echo º 8. Exit º
echo ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
choice /c12345678 /N Your choice:
if errorlevel 8 goto exit
if errorlevel 7 goto prompt
if errorlevel 6 goto setup
if errorlevel 5 goto editors
if errorlevel 4 goto multi
if errorlevel 3 goto mods
if errorlevel 2 goto cryptic
if errorlevel 1 goto blood
:editors
cls
echo º Menu º
echo º 1. Blood º
echo º 3.+ MODS º
echo º 5.- Editors º
echo º a. Art Editor º
echo º b. Map Editor º
echo º º
echo º 6. Setup º
echo º 8. Exit º
choice /c12345ab678 /N Your choice:
if errorlevel 10 goto exit
if errorlevel 9 goto prompt
if errorlevel 8 goto setup
if errorlevel 7 goto maps
if errorlevel 6 goto art
if errorlevel 5 goto start
:multi
cls
Show last 27 lines
echo  º        Menu         º
echo º 1. Blood º
echo º 3.+ MODS º
echo º 4.- Multiplayer º
echo º a. Startserver º
echo º b. Connect º
echo º º
echo º 6. Setup º
echo º 8. Exit º
choice /c1234ab5678 /N Your choice:
if errorlevel 7 goto editors
if errorlevel 6 goto connect
if errorlevel 5 goto startserver
if errorlevel 4 goto start
etc...
This is what it looks like in DOSBox:
https://youtube.com/@zirkoni42
Reply 4 of 8, by Egg shen
Application to create box by command line, windows xp or later
https://www.youtube.com/channel/UCCpuZuffdIcBcmqUEueXYeg
Download:
https://mega.nz/#F!y9YlWRYK!cuFUQYjjlC-LFbgG4k40GA
Reply 5 of 8, by keropi
http://reimagery.com/fsfd/menu.htm , check out "Medley" in "OTHER SMALL MENUS" section
Reply 6 of 8, by chinny22
ColdBrain wrote:
Oh well, thanks for the code! But I also wanted to learn to do them myself. Still, this will be very useful. 😀
But now you do!
Mess round with it and see how it works 😀
I do the same thing for old shareware titles like Duke Nukem, Jill of the Jungle, etc where each episode was a separate executable.
Reply 7 of 8, by Daniel3D
keropi wrote on 2016-06-20, 08:49:
The site has degenerated to the internet archive. But the zip is still available.
(although for me, the first solution worked wonderfully.) This is indeed a nice tool.
Medley is a small yet remarkably full-featured menu program. The program is only 6K and uses a modest 12K RAM when resident.
A second program is used for menu/display configuration, or you can manually create and edit menu files with a text editor.
Features:
  • Submenu capability (no more than two levels recommended)
  • Menu selection is accomplished with user-definable hotkeys- or by moving a menu bar to the desired item.
  • Option to prompt for filespecs/parameters when a menu item is selected.
  • Built-in pop up DOS command line menu option.
  • Menu title and colors are adjustable.
  • Built in screen blanker and date/time display.
Limitations:
  • Maximum of 20 menu items allowed per menu file.
  • No mouse support.
Author: Jim Knopf, aka Jim Button (1992).
1992-07-30 release.
    medley.zip
    30.46 KiB
    174 downloads
    I attach it for safekeeping
