First post, by jason_nepa
Hi All - I've been reading this forum for months now with this journey of mine, and finally had to create an account to ask the question. First of all, thank you to all of you for your time and expertise. It's been very helpful in getting to where I am at now.
I am trying to find the best way to use the MSI MS-6769 motherboard to play DOS games.
I have a HDD that has a 2GB partition that boots to a clean install MS-DOS 6.22. Windows 3.11 is also clean installed.
Everything is perfect so far, except I cannot get the Ensoniq ES1370 (PCI) to initialize in DOS mode. The driver (link below) is installed in Windows 3.11 and I am able to get sound with no problem there. Whenever I have AUTOEXEC.BAT, it freezes immediately after it executes INITAP.COM and never continues. I can't even terminate it manually. My only recovery is to boot to my other HDD with Windows XP, load the AUTOEXEC.BAT on the other HDD, and Rem the line that has INITAP.COM.
Some supporting pictures:
PXL_20231104_111141404.jpg (attached) shows my AUTOEXEC.BAT. You will see that I have BLASTER set to IRQ 10, which I explain on the next line.
PXL_20231104_111550645.jpg (attached) shows that I have most devices turned off and it sees the sound card at IRQ 10. Windows 3.11 also shows it on IRQ 10. So I believe that is correct.
PXL_20231104_111159439.jpg (attached) is my CONFIG.SYS. Not sure if it's important for this post, but it might be. So posting it anyway.
PXL_20231104_111410297.jpg (attached) shows exactly where my AUTOEXEC.BAT hangs and stops.
Two other points. I have L1 and L2 cache turned off. Secondly, I have a Creative Labs CT4750 that gives me the same exact problem. I bought the Ensoniq ES1370 when I realized the CT4750 may be "too new".
I like this motherboard because I feel like it was manufactured in that perfect period where it's not too old & not too new. I can also have another HDD and boot to Windows XP. I've been using Windows XP to drag driver files from that drive to the other for ease, but I will eventually use it for newer games once I perfect the DOS w/ sound/Win 3.11 setup.
Thank you for any pointers/help you can provide.
Ensoniq ES1370 driver. Used the apiwiz31.exe file (Windows 3.1 / DOS software):
https://www.vogonsdrivers.com/getfile.php?fil … menustate=47,38
Manual for the MSI MS-6769 motherboard:
https://www.manualslib.com/manual/802191/Msi-651m.html
