Turtle Beach Cancun FX
First post, by skel2raw
Hi guys,
I recently bought a Turlte Beach Cancun FX wavetable daugtherboard NOW CIB. Today I found the time to install into my retro pc. The daughterboard itself works. However, when I was about the install the software on the CD I couldn't find a serial number on the CD inlay. Somehow the serial disappeard throughout the years.
Does anyone have a serial number for the Cancun FX applications CD?
Thx!
Reply 2 of 5, by darry
Pretty sure I read about someone successfully contacting Turtle Beach about something like this relatively recently .
It's worth a shot .
EDIT: Found the post : Re: Turtle Beach Montego II Unboxing
If you could confirm Turtle Beach allow it for this product's serial number too, somebody might be inclined to share their serial number
Reply 3 of 5, by skel2raw
Unfortunately the serial number on the cd inlay either was never printed on it or the ink disappeared throughout the years.
I just tried installing with the serial number from my other Turtle Beach products and setup went through. I wonder whether the setup program installs anything specific depending on the serial used or it is just a check to let setup run through?
Reply 4 of 5, by CHiLL72
It is indeed just a check. As long as the installation runs after that, you're fine.
skel2raw wrote on 2020-08-18, 14:12:
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 5 of 5, by Ulfenknulfen
Hi all
I know - old Thread... but - could i have a copy of cancun-FX driver CD?
best regards
Ulf
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️🖱️USB HID Devices on PS/2 and Gameport.
