Reply 20 of 40, by sergio27ru
bios im checked - all IRQ's are free for ISA slots
MotherBoard is Asus P/i-xp55t2p4/pentium mmx 166. Doughterboard also checked with awe32.
Different ports/dma/irq - are also checked - quiet clicks.
Reply 21 of 40, by sergio27ru
appiah4 wrote on 2021-04-21, 14:30:
OK, just to make sure.. You actually have a wavetable daughterboard connected to the card, right?
Absolutely true! 😉))))
Reply 22 of 40, by appiah4
Can you do ESSVOL and take a photo of the output?
Reply 24 of 40, by sergio27ru
one stuff is possible with missmelody - i didnt found manual for this one, only photo of few jumpers description - base port/irq/dma, but onboard a lot of another jumpers and possible MPU is hardware disabled. I dont know...And thet's why few years ago, when tried DB on all es688 cards and agree with guys, that this chip is unsupported MPU401
ps: appiah4 - your's card is a litle differ, dont know - does it matter or not.
Reply 26 of 40, by sergio27ru
gdjacobs wrote on 2021-04-21, 21:27:
Can you further subdivide the problem and check for MIDI serial output on the wavetable header and on the ES688 MIDI out pin (GP […]
Can you further subdivide the problem and check for MIDI serial output on the wavetable header and on the ES688 MIDI out pin (GPO1)?
http://ohlandl.ipv7.net/sound/ESS688_Datasheet.pdf
you mean - check the signal gp1 on the chip and WT header?
Reply 27 of 40, by Joseph_Joestar
sergio27ru wrote on 2021-04-22, 01:18:
Before suspecting the hardware, take a detailed look at your ESSVOL.EXE parameters. Specifically, check whether the "A" parameter is set to higher than zero.
Someone had a similar issue here: ISA ESS AudioDrive, ES1868F - No Midi in DOS
My retro builds
Reply 28 of 40, by Stiletto
ESS didn't call that a datasheet incidentally (on their old website), they called it a "product brief". I always suspected there was a longer document they called a datasheet, but so far, it's lost. But maybe I'm wrong and it was just different strokes for different folks.
do the Fandango!" - Queen
Stiletto
Reply 29 of 40, by gdjacobs
Joseph_Joestar wrote on 2021-04-22, 01:58:
The ES1688 has an Aux channel, but the ES688 does not.
Just to be clear, I'm assuming you're trying to drive the WT header and not run a module via the game port. With that proviso...
If MIDI output is active, GPO1 on the ES688 chip will be flickering. If that pin is showing activity, but the WT header isn't, you have a signal path issue and need to check passive components and trace continuity.
Reply 30 of 40, by badmojo
Have tried disabling everything possible in the BIOS? Serial ports, etc? Maybe a resource conflict with the motherboard?
Reply 31 of 40, by sergio27ru
As you look pictures 4,6,7.jpg - y'l see that A (AUX) dint zero and equal 8.
Reply 32 of 40, by sergio27ru
gdjacobs wrote on 2021-04-22, 02:10:
The ES1688 has an Aux channel, but the ES688 does not. […]
Ok, good idea, thx, which WT holder's pin should i check?
Pin 58 (es1688) signal: WO active MIDI - (Hight level) = constant 5 V
With playing MIDI - (Hight level) + data going
And one more - please, dont forget - measurements done on the modifiedGOLD16 board with es1688 chip (not 688)!!!! (another es688 - missmelody card didnt see MPU port w/wo any settings)
Reply 33 of 40, by sergio27ru
badmojo wrote on 2021-04-22, 02:18:
already done and rechecked, in my case - i didnt try IRQs 4,3 only - why?! Test stand is MB + VideoCard:
Reply 34 of 40, by gdjacobs
sergio27ru wrote on 2021-04-22, 03:52:
Excellent!
Waveblaster Pinout:
https://www.epanorama.net/documents/pc/waveblaster.html
If that pin checks out, verify the voltage supply for the WT board (which I assume is known good) and begin looking at mixer or analog signal path issues.
Does ENMPU load on the MissMelody card or does it show an error?
Reply 35 of 40, by Pierre32
Enjoying this thread. Looks like I'll be spending another Saturday trying to get the MPU working on my ES688 card!
Reply 36 of 40, by Rawit
For the first card in the thread; did you use es968.com in config.sys? It performs some P&P tasks and enables the MPU. Needed it for my ES1688 +ES968 to get it going.
For the Gold-16, have you tried toggling the software address jumper? And check if it's doing SB-MIDI through port 220.
YouTube
Reply 37 of 40, by Babasha
Hi! Same card is on the way to me. Will test it soon and report here)))
I think everything will be ok and i show you (and Hustler)… откуда готовилось нападение на Беларусь 😀
Need help? Begin with photo and model of your hardware 😉
Reply 38 of 40, by Babasha
sergio27ru wrote on 2020-12-21, 05:00:
Hello all! I've got a problem with es1688+es968+qs700: esfm work well 220/5/1/330, but onboard wavetable doesn't work by any settings\jumpers configuration, also dosn't work external wavetable. I'm think - that needed software activation programm (or card is dead). Does somebody have an expirience with this cards and mpu? please help!
Hi!
I won it in 20 minutes)))
On the photo in the attachment standard positions of the jumpers
ATTENTION!
JP3 PNP_EN - in a OPEN state! In this state, the PNP mode is turned ON (!!!)
Further in this mode, the Win98 is loaded, the drivers are configured automatically and the soundcard works perfectly in Win98 (the sound and all 3-4 synthesizers - Midi Mapper with OPL3 sound or what is , ESS MPU - works on board WaveTable and some other synthesizers Ess FM which is also similar in the previous sound).
Next, go to DOS and initialize the card using Unisound 0.80 without keys - it finds and launches a card in PNP mode and silence in General Midi mode at 330 port 🙁
Carefully read the documentation of Unisound, and there is a special key /NOPNP (just for the bunch of ESS1688+ESS980) and start Unisound /NOPNP
Taaadaaammm! Hurray appeared sound in General Midi on port 330
Clarification
UNISOUND in my case needs to be run 2 times
1) UNISOUND (without keys) - initializes the card in PNP mode, but without the sound of the built-in wavetable
2) UNISOUND /NOPNP - reinitializes the card in NOPNP mode and there is a sound from the built-in wavetable
THATS ALL!
Reply 39 of 40, by Jccwu
Спасибо друг, получилось таки!
Sound card's music
