Reply 180 of 487, by ruthan
- Oldbie
wrote:The ALS4000 is also a potential contender.
I found 2 threads:
The ALS4000 PCI Sound Card - PCI SB Compatibility in Newer Systems
Interesting - ALS4000 DOS support
In both is this or similar note:
Intel i810 or later do not support Distributed DMA for legacy DMA support for PCI.
If you want SBPro function in pure DOS on Intel i8xx based motherboard, try Fortemedia FM801.
FM801's writeback DMA emulation method may work on Intel i8xx.
There is also nothing about more modern Via chipsets etc.. What i dont fully understand is in first thread was used i865 MB, but is not listed as compatible, maybe testing was in done in Windows.
It does not look hopefully.. I just need confirmation, that sound card works on some chipset in pure DOS, et least for few games, after make sense to order card and do proper testing.
Update from 1st thread:
The readme file for als4000 says that the chipsets i810 and later "do NOT work". But my system is a i865 chipset and it still works. Maybe I should drop a note to him (saka) that it works in this chipset. Maybe he can do something for faster systems, looking at the portential of this als4000 chip.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
