First post, by Stiletto
- l33t++
Saka slapped up a support page and compiled a sound initialiser for the ALS4000 sound chip. There is no need for TSR, no HIMEM.S […]
Saka slapped up a support page and compiled a sound initialiser for the ALS4000 sound chip. There is no need for TSR, no HIMEM.SYS, no EMM386.EXE for SB compatibility with this chipset and the above initialiser. This will work with...:
AMD 750
AMD 761 & VIA VT82C686B (tested by Q)
Intel 430TX
Intel 440BX
SiS 630
SiS 730
SiS 735
SiS 745
VIA ApolloPro133
VIA PLE133
...chipsets.
http://vsynchmame.mameworld.net/als4kdos/
Unfortunately Intel i810 and Intel i815 or later will not work because they do "not support Distributed DMA for legacy DMA support for PCI. If you want SBPro function in pure DOS on Intel i8xx based motherboard, try Fortemedia FM801. FM801's writeback DMA emulation method may work on Intel i8xx".
http://www.google.com/search?hl=en&lr=&ie=UTF … um=100&filter=0
Thanks to KillerClown of http://www.mameworld.net for the news!
do the Fandango!" - Queen
Stiletto
