Reply 500 of 744, by Falcosoft
- Oldbie
wrote:But sometimes, the instruments keeps on getting somewhat "water splash" effects when I play a note or a MIDI song and I have to restart the MIDI Player to get rid of the effect 😒
Instead of restarting anything you should try to reset SC-VA by using Options->System->Reset button or by setting your Midi Player to send GS Reset SysEx messages between songs. It should work.
SC-VA does not know that a midi file finished playing and the effects set by a file remain active without explicit resets.
