First post, by PhilsComputerLab
A while ago I documented this project of using a Windows notebook with a USB MIDI interface, running Munt and VirtualMIDISoft and turning it into a MIDI Module.
gdjacobs applied this idea to the Raspberry Pi and he got the Munt emulator fully working.
I've only just got the Raspberry Pi so it was a steep learning curve and at first I am focusing on General MIDI, will checkout MT-32 emulation at a later stage. All up in took me a day or so to figure everything out. I know a lot more about the Raspbian OS and Linux, although I'm still a noob but that's ok 😊
dsc-5738.jpeg?1482217590
I have done a thorough write-up of steps required to get this going and put it on a page on my site. I couldn't figure out an easy way to copy / paste that contents to here I'm afraid.
I am using a Roland UM-ONE MKII as USB MIDI interface. No drivers are necessary, it was plug and play.
dsc-5714.jpeg?1482217398
You will need a MIDI coupler to connect everything together:
dsc-5720.jpeg?1482217788
If you are new to the Raspberry Pi and not familiar with Linux, don't worry. The entire project can be setup using Graphical User Interfaces. It's really straight forward:
Qsynth is an easy-to-use front-end for FluidSynth.
The only issue I had was distorted sound and it was required to change Audio Driver, Buffer Size, Buffer Count and Polyphony settings as per image below:
With patchage we create a link between the USB MIDI interface and FluidSynth.
And that's it! Knock yourself out with trying different SoundFont files. The Crysis font seems to be too large, but all the "standard" SoundFonts work great.
There is one more issue with the onboard analogue audio out. It's really poor. A USB sound card is needed. I've ordered it, but will update the guide once it arrives. I've been using the HDMI audio in the meantime. You could also use a HDMI audio stripper, but that costs quite a bit more.
Hopefully others have a go at this and develop it further. An enclosure? LCD display with buttons to select SoundFonts and reset the unit? Lots of things that can be done.
Reply 1 of 53, by c0keb0ttle
Fantastic! Will there be a video on this in the near future?
Reply 2 of 53, by PhilsComputerLab
A video? From me? No way! 🤣
Of course 😊
Reply 3 of 53, by BloodyCactus
fluidsynth comes with a 128mb GM soundfont that is pretty awesome.
sudo apt-get install fluid-soundfont-gm fluid-soundfont-gs
and it appears in
/usr/share/sounds/sf2/FluidR3_GM.sf2
GS sf2 is only like 3?mb, in same directory.
Reply 4 of 53, by Zup
BloodyCactus wrote:
fluidsynth comes with a 128mb GM soundfont that is pretty awesome. […]
and it appears in
I guess that GS soundfont is "stacked" on top of GM sound font, so it can use instruments from GM without taking extra disk space.
I'm selling some stuff!
Reply 5 of 53, by PhilsComputerLab
Yup, and it does sound nice.
I believe when I ran
sudo apt-get install fluidsynth
it prompted me and asked if I wanted the SoundFont. It also installed Qsynth automatically.
Reply 7 of 53, by PhilsComputerLab
Dominus wrote:
Nice, thanks for the write up!
No problem 😀
Reply 8 of 53, by Ampera
For some reason I am unable to find a single place where there is a gameport to MIDI cable. I have no clue where they are or how to buy them. Any tips? Communist Ralph on your videos btw.
Reply 10 of 53, by Ampera
PhilsComputerLab wrote:
There are likely cheaper ones, but this is the first one I found: http://www.ebay.com.au/itm/Electric-Piano-Org … 5kAAOSw0UdXtW1D
Thanks!
That one doesn't ship to the US, but these do.
http://www.ebay.com/sch/i.html?_from=R40&_trk … o+MIDI&_sacat=0
I never searched using DB 15 to MIDI, and that's where they were hiding.
Reply 11 of 53, by James-F
This is a nice idea BUT:
To see something you still have to connect a monitor to it, mouse and keyboard are also necessary to control the PI.
You have to be a PhD in Computer Science do the simplest things in Linux, steep learning curve is a gigantic understatement. 😐
A small Windows based laptop is still a much simpler solution as a MIDI box, while the Raspberry PI (or Linux/Unix in general) is reserved for the extreme tweakers.
Reply 12 of 53, by BloodyCactus
you can use putty on windows and ssh in. no extra keyboard/mouse/monitor required.
Reply 13 of 53, by James-F
Remote controlling the Pi using a Windows PC still requires the Windows PC... why not just use that very same Windows PC?
Reply 14 of 53, by Ampera
James-F wrote:
This is a nice idea BUT: To see something you still have to connect a monitor to it, mouse and keyboard are also necessary to co […]
Bullshatner. Linux is as easy to use for most functions as windows. Console use is a bit of a faff, but it's the same in windows.
Reply 15 of 53, by brostenen
This might interrest someone. There is startup/shutdown scripts in this toturial.
Been looking at this, alongside other information, for creating my version of a cheap synth.
http://www.instructables.com/id/PiMiDi-A-Rasp … w-I-Learned-to/
Reply 16 of 53, by brostenen
CLI is like a Dos-prompt on steroids.
Reply 17 of 53, by Ampera
Not entirely sure what your talking about...
Reply 18 of 53, by brostenen
CLI = Command Line Interface.
Reply 19 of 53, by Ampera
Yea I know that, but how is the relevant? Which CLI? Are you talking about bash, batch, what?
