Reply 220 of 455, by matze79
Yeah just put it on different Address and write some Software 😉
Got ESD Bags today, so i can package everything today 😀
Reply 221 of 455, by matze79
109.56 KiB
Everything is packaged, so be prepared 😀 it will be TANDYcous 😁
Reply 222 of 455, by hasnopants
Im excited! Thanks Matze!
I might have missed it so apologies if I did...also might be a stupid question but is there a TSR to load with this to make it work or should it 'just work' when using it with tandy sound compatible software?
Thanks!
Current Systems:
DIP40|8088|640K|HERCULESGB102|PCSPKR
DIP40|V20|640K|VGA|ADLIB/TNDY/COVOX
S7|P233MMX|128M|S3ViRGEDX/DM3D|SB16
S370|P600MMX|256M|SIS630/DM3DIIX2|SBLIVE!5.1
S775|P43.4|2G|6800GS|SBAUDIGY
Reply 223 of 455, by root42
Some software will work out of the box on the standard Tandy port (0c0h IIRC). Some requires patches, like Zak McKracken and Maniac Mansion, see here:
VGA machine and Tandy audio for Maniac Mansion?
Many Sierra games will allow you to choose Tandy sound during setup.
YouTube and Bonus
Reply 224 of 455, by matze79
Planet X3 runs out of the Box:
https://youtu.be/wefxodVLaLw
There are some noise also because of running 3D Printer and ehm Girlfriend playing RDR2.
Planet X3 works out of the Box 😀 WoW and Sounds good!
Some Patches are here:
ftp://ftp.oldskool.org/pub/TandySoundPatches/
Prince of Persia needs some hex patching you need to unpack the exe and then hexedit a little bit to enable /tandy option.
Then it will work fine 😀
Reply 225 of 455, by Benedikt
And adding support for alternative port addresses should not be too difficult either. Well, maybe later.
Reply 226 of 455, by matze79
And maybe for Tandy LPT Device ? 😀
Reply 227 of 455, by Benedikt
The most pragmatic solution is probably integrated support for Tandy emulation TSRs at interrupt vector C0h.
An appropriate TSR could then redirect everything to a different port or emulate the SN76489AN on an SAA1099P or even a SID without cluttering Planet X3's code base with code that hardly anybody needs.
Reply 228 of 455, by matze79
maybe.. dreamblaster will bring soon his lpt based tandy soundcard and also had a saa1099 prototype for the lpt port 😀
we trying to get a driver that works without qemm386 now, alpha driver is already working 😀
if planet x3 works with temu, it also should work with tndlpt.
had no time for trying it yet.
All packages are send, hopefully they will arrive Fast 😀
EDIT:
you should get a E-mail from DHL with Tracking Number and Information.
Thanks very much for supporting this Project 😀
Reply 229 of 455, by matze79
https://youtu.be/KOHDFntRbGA
SN76489 at 1E0 on 386 System using Port Redirector playing Planet X3 Music 😀
Reply 230 of 455, by hasnopants
Thanks! I havent seen a tracking yet. Will keep an eye out for it.
Current Systems:
Reply 231 of 455, by matze79
Did you look in your Spam Folder ?
if it does not work i send them manually 😳
Reply 232 of 455, by hasnopants
Just checked again, yeah nothing in spam either.
If you could PM mine that would be great.
Thanks!
Current Systems:
Reply 233 of 455, by root42
Mine has been delayed by DHL‘s stupidity. Can’t wait for it to hopefully arrive on Monday.
YouTube and Bonus
Reply 235 of 455, by matze79
Port Redirection Driver / Source Code is avaible.
Its still experimental.
https://github.com/JKnipperts/TNDY
Reply 237 of 455, by matze79
due to many requests.. just add yourself to this google spreadsheet,
so we can estimate how many cards need to be made, or Building Kits.
For Building kits, there are two Designs of the Card, one in SMD and one in DHT.
But only one will be made.
https://docs.google.com/spreadsheets/d/1Fevrq … dit?usp=sharing
Thank you all!
Matthias
Reply 238 of 455, by hasnopants
Got my card today Matze! Can't wait to try it out, thanks!
Current Systems:
Reply 239 of 455, by matze79
https://www.retroianer.de/sndoff.zip
You need Scalis channel muting Com Files or https://www.retroianer.de/SNDOFF.EXE .
Not updated yet for new Card Addresses.
i wanted to write some sort of manual but had no time now.
Glad you got the Card, faster then expected ! 😀
