Reply 220 of 499, by matze79
Yeah just put it on different Address and write some Software 😉
Got ESD Bags today, so i can package everything today 😀
Everything is packaged, so be prepared 😀 it will be TANDYcous 😁
Im excited! Thanks Matze!
I might have missed it so apologies if I did...also might be a stupid question but is there a TSR to load with this to make it work or should it 'just work' when using it with tandy sound compatible software?
Thanks!
Current Systems:
DIP40|8088|640K|HERCULESGB102|SB1.0
DIP40|V20|640K|VGA|ADLIB/TNDY/COVOX
S7|Pentium|128M|S3ViRGEDX/DM3D|GUS
SL1|PII|128M|RIVA128|STBV2|AWE64G
S370|PIII|256M|SIS630/DM3DIIX2|SBLIVE!5.1
S775|P4|2G|6800GS|SBAUDIGY
Some software will work out of the box on the standard Tandy port (0c0h IIRC). Some requires patches, like Zak McKracken and Maniac Mansion, see here:
VGA machine and Tandy audio for Maniac Mansion?
Many Sierra games will allow you to choose Tandy sound during setup.
Planet X3 runs out of the Box:
There are some noise also because of running 3D Printer and ehm Girlfriend playing RDR2.
Planet X3 works out of the Box 😀 WoW and Sounds good!
Some Patches are here:
ftp://ftp.oldskool.org/pub/TandySoundPatches/
Prince of Persia needs some hex patching you need to unpack the exe and then hexedit a little bit to enable /tandy option.
Then it will work fine 😀
wrote:Planet X3 runs out of the Box:
And adding support for alternative port addresses should not be too difficult either. Well, maybe later.
And maybe for Tandy LPT Device ? 😀
The most pragmatic solution is probably integrated support for Tandy emulation TSRs at interrupt vector C0h.
An appropriate TSR could then redirect everything to a different port or emulate the SN76489AN on an SAA1099P or even a SID without cluttering Planet X3's code base with code that hardly anybody needs.
maybe.. dreamblaster will bring soon his lpt based tandy soundcard and also had a saa1099 prototype for the lpt port 😀
we trying to get a driver that works without qemm386 now, alpha driver is already working 😀
if planet x3 works with temu, it also should work with tndlpt.
had no time for trying it yet.
All packages are send, hopefully they will arrive Fast 😀
EDIT:
you should get a E-mail from DHL with Tracking Number and Information.
Thanks very much for supporting this Project 😀
SN76489 at 1E0 on 386 System using Port Redirector playing Planet X3 Music 😀
Thanks! I havent seen a tracking yet. Will keep an eye out for it.
Current Systems:
Did you look in your Spam Folder ?
if it does not work i send them manually 😳
Just checked again, yeah nothing in spam either.
If you could PM mine that would be great.
Thanks!
Current Systems:
I'm interested in this card too, but I can't send a PM yet since I'm too new and not authorized to send PMs.
Port Redirection Driver / Source Code is avaible.
Its still experimental.
I would like to purchase one card too, and of course the cool sticker! Sorry cannot send PM,
due to many requests.. just add yourself to this google spreadsheet,
so we can estimate how many cards need to be made, or Building Kits.
For Building kits, there are two Designs of the Card, one in SMD and one in DHT.
But only one will be made.
https://docs.google.com/spreadsheets/d/1Fevrq … dit?usp=sharing
Thank you all!
Matthias
Got my card today Matze! Can't wait to try it out, thanks!
Current Systems:
You need Scalis channel muting Com Files
Not updated yet for new Card Addresses.
i wanted to write some sort of manual but had no time now.
Glad you got the Card, faster then expected ! 😀
