First post, by m5215tx
I found one of these for what seemed to be a reasonable price compared to all the CM-32L units that I have seen for sale so I went ahead and purchased it. It's on its way to me from Japan so I don't have it in my possession yet. It looks to be in new condition and has been verified to work with no problems. Not sure if it's true or not but from what I have heard the CM-32LN is a rarer find than the original CM-32L.
From what I understand it is the final version that was released of the CM-32L but works just like it. The case style looks a bit sleeker than the original CM-32L.
Does anyone know of any outstanding differences or improvements this version has over the original CM-32L?
Also, on the back there are 2 sets of MIDI input/output jacks. One set is labeled LA and the other MPU. I am going to be using this with DOSBox set to intelligent MIDI so I assume I would be only using the MPU input, right? Not sure what the LA input/output MIDI jacks would be used for but I assume for my use they will not be needed. If anyone can confirm my thoughts on this that would be great. This device was not cheap so I don't want to risk damaging it.
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 1 of 10, by Shponglefan
AFAIK, the CM-32LN has the faster vibrato (same as the CM-500). This will result in certain instruments sounding a bit different when vibrato is used; Space Quest III intro for example.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 10, by m5215tx
OK, then I should probably plan on keeping my MT-32 since I would assume it does not have this difference.
Now that I think about the MT-32, I wonder if the CM-32LN works as an original old version MT-32 or the newer revision? I know some games support one or the other. My MT-32 is the original older version so I would think the CM-32LN would likely work as the newer MT-32. That would be nice to have full MT-32 support coverage between the two.
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 3 of 10, by m5215tx
Are there any members of this forum that own a CM-32LN?
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 4 of 10, by Jo22
Well, I own a CM64.. Not sure, though, if its internal CM32L is a CM-32LN type. 🙁
Reply 5 of 10, by Cloudschatze
I have a couple of CM-32LNs.
The CM-32LN was designed to complement NEC's "98-Note" line of portable computers, hence its aesthetics, dimensions, lightweight build, and optional battery-powered functionality. It's the equivalent of an external LAPC-N, combining the same third-generation LA sound-source (as also found in the CM-500), and a full MPU-401N interface.
The CM-32LN can be directly connected to a 98-Note system via the 110-pin bus (through use of the corresponding adapter cable), allowing it to function both as an independent MIDI interface and synthesizer. Unless you have such a system, you'll want to concern yourself with just the "LA" MIDI IN/OUT ports for regular use otherwise.
Reply 6 of 10, by m5215tx
Thanks for that specific comment as I was not sure which set of MIDI inputs/outputs to use. I already have a Roland UM-ONE Mk2 USB MIDI cable so I am ready to go.
I noticed there is no MIDI thru on this unit. I have several MIDI sound modules that I am going to all connect together. All the others have MIDI thru except this one. Is the signal coming out of the LA MIDI OUT going to be unchanged so it's handled correctly by other MIDI sound modules?
My post office is holding the package for my CM-32LN so I will be getting it tomorrow. Looking forward to hearing it in action! 😁
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 7 of 10, by NewRisingSun
It's always a treat to see Roland hardware in the stylistic context it was designed for. 😀 Consider the following image from a Japanese Roland advertisement on how the regular CM series was designed to fit in with the NEC PC-9801 series of computers, in particular the NEC PC-9801 RA/RX:
You're supposed to place it upright! 😉
I have never seen a CM-64 with anything other than a normal CM-32L inside. What does the vibrato sound like?
Reply 8 of 10, by Cloudschatze
That's correct. You'll want to make the CM-32LN the last device in your chain.
Reply 9 of 10, by m5215tx
Thank you Cloudschatze! You have been very helpful!!
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 10 of 10, by m5215tx
Wow, you were not kidding. The Space Quest III into sounds better on the MT-32 than it does on the CM-32LN. I wonder how common the vibrato issue comes up? All the other games I tested sounded great on the CM-32LN so hopefully this is a rare issue. In general the CM-32LN does seem to have a "cleaner" sound to it in comparison to my MT-32 so that is great. In spite of the vibrato difference, I am happy to have the CM-32LN.
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
