First post, by Baoran
I got my hands on this sound card recently.
3.86 MiB
3.9 MiB
Sticker says ES1371 but there is ES1373 written to the chip itself, so either there was a mistake or they are the same chip. Anyone knows?
Would it be possible to make this card work in dos and where I could get drivers for it?
I remember hearing some of the ES chips had some kind of dos compatibility.
Reply 2 of 15, by Baoran
Hopefully it is better than just pc speaker. I do also have sound blaster live that I could try to see how well sound blaster emulation works. Any idea which one is better option? Or would it be better to buy one of those aureal vortex 2 cards for dos?
Reply 3 of 15, by Kamerat
The Sound Blaster Live! DOS emualtion are based around the Ensoniq AudioPCI (ES1370, ES1371 and ES1373) DOS emulation so it will sound similar and have the same game support. Sound Blaster PCI are actually just rebranded Ensoniq AudioPCI and share the same drivers.
YouTube channel
Reply 4 of 15, by Jo22
Hey, that card looks like an AudioPCI 3000, which I used months ago to make a SoundScape recording of Crusader: No Remorse! ^^
Reply 5 of 15, by chinny22
This was a real messy time for creative, as they also call it a Sound Blaster 64 PCI, You can read more about it here, but basically they just wanted the dos emulation drivers and didn't know what to do with the soundcard itself. Make sure you get the 8MB ecm file.
Ensoniq / Creative AudioPCI
So the SoundBlaster Live is the better card as amongst other things supports EAX and soundfonts but only marginally IMHO, being from the same era I would say it is a model up.
Your much better off getting an Audigy 1 2 or ZS, they still use the same Dos legacy files but the windows side of things are much more improved and support later EAX versions.
Vortex 2 is completely different (like Intel to AMD or Nvida to ATI)
You will loose EAX, soundfonts, but gain A3D 2.0
Really which is better is down to personal preference, I like the stable (if bloated) drivers of Creative, EAX is more widely supported and Creative cards are much more common and affordable. I wold love a Vortex 2 to play round with though
Reply 6 of 15, by Jo22
leileilol wrote:
You've got yourself a common AudioPCI. It does have DOS drivers and they're all easily available. Enjoy the bad "FM"!
Right, though its FM implementation is technically interesting, it really is a torture to the ears. 😵
This is about what someone can expect when playing FM via SoundScape/AudioPCI:
https://www.youtube.com/watch?v=RzoloT5eRtY
Anyway, the Audio PCI is quite nice for MIDI, at least. ^^
https://www.youtube.com/watch?v=-Zz-OFYTQLE
Thanks for sharing that link with us - I never got that thing to work in early Win95.. 😉
Good ol' Win 3.1 was bit more cooperative, however. After a little bit of trial and error, it worked fine.
Windows 98SE is perhaps fine, too. Unfortunately, my GA586 mainboard still refuses to run Win98.
Reply 8 of 15, by Srandista
Elite FM is the best, you'll never hear this anywhere else 😁
https://www.youtube.com/watch?v=YXFYWJ7dbz0&t=2400s
Socket 775 - ASRock 4CoreDual-VSTA, Pentium E6500K, 4GB RAM, Radeon 9500@9700, ESS Solo-1, Win 98/XP
Socket A - ASRock K7S41GX, AMD Athlon XP 3000+, 512MB RAM, GeForce4 Ti4200, SB Live, Win 98
Reply 9 of 15, by zecahue
I have got a MB with a onboard 1373 chip on it, so my guess is that it should perform, if not identical, at least very close to the card from this topic. My question for you guys is: is it worthy to get a Live card only to play late 90s and very early 2000s titles? I do have other machines with sbpro2 and awe64, so back compatibility and FM synth are out of questions here. I know the Live is an improvement, but is it a lot (really noticeable)?
Reply 10 of 15, by chinny22
Gateway PC by chance?
It's what I used back in the late 90's and for about 3 weeks when I went back to Australia this year.
I doubt I'll ever upgrade them but then I have other PC's that do have EAX capable sound cards.
Some games are better then others but not having EAX doesn't make any game less enjoyable.
I'd say its more a case of with Live! cards being so cheap now most people get one to cover all their bases.
Reply 12 of 15, by Boohyaka
Jo22 wrote on 2017-12-15, 05:25:
Damn, that SCUMM bar theme immediately rose to 1st place of the most sad & pathetic thing I've heard in 2022, only to be relegated to 2nd place by that poor Doom E1M1 on the Elite 1 minute after .__.
Reply 13 of 15, by swaaye
They are like the cheapest sound card 1997 could make which is what those big computer companies want. Along with some brand recognition in Ensoniq. Just an early AC97 codec on a PCI card with host-based MIDI, FM, effects, EAX and A3D processing that is designed with the limitations of a Pentium MMX in mind. They do sound pretty good for just playing back PCM though.
Reply 14 of 15, by dr.zeissler
Is there a "bigger" difference between ES1371 and ES1373 ? The OS/2 driver for the ES1371 does not seem to work with the ES1373.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 15 of 15, by chinny22
dr.zeissler wrote on 2023-02-17, 19:47:
Yes, few different drivers exist
Different Versions of Ensoniq AudioPCI
