Reply 100 of 122, by Scali
jaZz_KCS wrote:
This just sounds too good to be true.
It should be possible to make a native MIDI driver for Win3.x... the driver itself is probably not very difficult: you get MIDI bytes from the Windows MIDI mapper interface, and you output them to the printer port.
But I have no idea what tools would be required, or what such a MIDI driver has to look like for Windows 3.x. I wonder if it's still possible to find documentation on that, perhaps even a sample.
I have a copy of Visual C++ 1.52, I could check if it has the required documentation. But it might require some Windows DDK that I don't have.
Edit: Perhaps these are useful: https://winworldpc.com/product/windows-sdk-ddk/windows-31
Reply 101 of 122, by root42
You might want to ask the Wine people. They probably know the APIs in and out.
YouTube and Bonus
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, SnarkBarker & BlasterBoard, PC MIDI Card + SC55 + MT32, XT CF Lite, OSSC
Reply 102 of 122, by matze79
Maybe it helps
Here is a Driver with Sourcecode that plays MIDI on the PC-Speaker.
SMIDIDR3.7z
83.46 KiB
13 downloads
Its written in DELPHI 1.0.
Here is some Discussion:
http://www.vcfed.org/forum/archive/index.php/t-50867.html
I also own S2P and its cool.
Doom runs with Patcher 😉
Co2 - for a endless Summer
Reply 103 of 122, by dreamblaster
Wohooo!
Scali wrote a great blog article on S2P : https://scalibq.wordpress.com/2019/03/09/dreamblaster-s2p/
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
Reply 104 of 122, by dreamblaster
S2P demo of midi playback and DOS games with softmpu mt32 mode , by Ki-Hyun Cho : https://youtu.be/VasXlFR-FKQ
- monkey island : https://youtu.be/VasXlFR-FKQ?t=494
- police quest 2 : https://youtu.be/VasXlFR-FKQ?t=645
- zeliard : https://youtu.be/VasXlFR-FKQ?t=813
Reply 106 of 122, by pdw
Unfortunately, patching games for S2P support turned out to be a bit too difficult. s2ppatch only supports two audio engines:
- the DMX engine, used by Doom / Heretic / Raptor: Call of the Shadows
- some versions of the Miles Sound System.
If your games come with a 'mt32mpu.adv' file you're in luck. If not, I'm afraid it won't work.
The recommended way to use the S2P is with softmpu, but that of course requires a 386.
I see some discussion of a Windows 3.1 driver. I believe Microsoft in fact published the source code of some of the basic Windows 3.1 sound drivers as part of the Multimedia SDK. Modifying them should be 'doable' for somebody with Windows 3.1 C+asm programming experience...
Reply 107 of 122, by Scali
Perhaps the good ole FPU emulators could give us a hand?
The MPU-401 interface basically only has two ports: 330h and 331h.
Each port can be read and written to. So you have a total of 4 different entry points into the MPU-401 state machine.
Now, let's say you create 4 int handlers:
int 30h: read port 330h
int 31h: read port 331h
int 32h: write port 330h
int 33h: write port 331h
Now you could create a TSR that implements the MPU-401, that can be loaded before the patched game.
Patching itself is reasonably simple: just find all reads and writes to port 330h and 331h, and patch them in-place with the proper int-call.
For UART mode, the TSR should be quite trivial.
For intelligent mode, I suppose the biggest problem is handling the timing. If any game reprograms the timer, you can't use it. Not too many games do, it seems, but still.
That makes me wonder... would a DreamBlaster S2P 2.0 be possible? One that has some kind of timer built-in, which can be read back by the TSR? Perhaps even generating interrupts on the LPT at a given interval, so it would be relatively easy to implement the timing required for intelligent mode?
Then you'd be able to get around the 386+ requirement for SoftMPU.
Reply 108 of 122, by dreamblaster
Scali wrote on 2018-02-05, 11:01:
I've never written a driver for Win3.x, but I have written a MIDI driver for Windows 10, based on MUNT.
So based on that code, it should be possible to make it output to a DreamBlaster S2P.
If someone has some example code for a MIDI driver for Win3.1, then perhaps we can get that working as well.
Hi
Andri made an updated win 3.11 midi driver for opl3lpt...
https://github.com/andreiw/adlib21
maybe it can inspire ?
Reply 109 of 122, by matze79
not really, as driver was already existing, he just changed the io part to lpt 😀
This is Microsoft Adlib Driver 😀
Reply 110 of 122, by matze79
Is the MPU driver also opensource ? it would be very similar to modify it..
Reply 111 of 122, by jaZz_KCS
matze79 wrote on 2020-02-12, 18:40:
Please make this happen, if possible. As the Win3.1/3.11 driver opens up a whole new world of opportunities for the OPLxLPT, so would a driver in the same veins for the Dreamblaster S2P. Imagine giving 386 luggables without a sound card the luxury of midi within Windows 3.1/3.11 paired with the PC speaker sound driver..
Reply 112 of 122, by derSammler
The S2P is an external device that also requires power. I don't see why on a "386 luggable" you could not just connect a GM module over the serial port instead. This will work in Win3.1 just fine.
Apart from that, with SoftMPU, the S2P should work in Win3.1 already.
http://retro-net.de/blog.html
Reply 113 of 122, by jaZz_KCS
derSammler wrote on 2020-02-13, 09:37:
Could you please elaborate on that? Last time I checked, SoftMPU does not support Windows 3.1/3.11... at all. Something to do with with EMM386 making this impossible, iirc.
So how would I be able to use the S2P under Windows 3.11?
Reply 114 of 122, by matze79
Hm win /s will not work with emm386 in protect mode ?
Reply 115 of 122, by derSammler
Not sure what you mean. SoftMPU needs EMM386 and Windows 3.1 even comes with it. I don't see where it should conflict. The readme file of SoftMPU doesn't state any incompatibilities with Win3.1 either. The only thing you should not do is installing the MPU-401 driver that comes with Windows, as that is for the actual Roland interface card.
Reply 116 of 122, by matze79
the adlipt tsr also does not work with windows 3.x, and it also uses port trapping etc.
so i guess softmpu will also not work with windows midi.
Reply 117 of 122, by matze79
Here is some Info about it:
Re: SoftMPU build for Windows support?
so indeed a windows driver is needed to achieve s2p midi in 3.x
Reply 118 of 122, by jaZz_KCS
matze79 wrote on 2020-02-13, 14:27:
That's what I remembered. I also remember trying it before reading that and never got it to work.
Reply 119 of 122, by dreamblaster
Retro Erik made a review of S2P, it shows S2P with a lot of games ! : https://youtu.be/bI-TJjKvv_Y
