First post, by madrobby
I have a brand-new Dreamblaster X2 that's working great on my CT2800 Soundblaster 16.
Is there a way to use MIXERSET.EXE to control the volume & whether it outputs anything at all? I believe it just gets sent the MPU-401 data that's also sent to external devices. But obviously if I want to use an external MIDI module, I don't want the Waveblaster part of the sound card on (or it should be a 0 volume).
Is this possible with MIXERSET.EXE or another DOS-based utility? Or do I have to use the USB-based modern PC settings app for the X2?
