First post, by Kahenraz
I always liked vertical CMOS battery holders. Until now.
I thought about moving the capacitors to the opposite side of the board, but they are surface mounted and not through-hole.
The attachment 20220423_024151_resize_19.jpg is no longer available
Reply 2 of 10, by Kahenraz
It would still collide with the little arm that holds it in place.
The attachment 20220423_025058_resize_48.jpg is no longer available
Reply 3 of 10, by Joseph_Joestar
I've had a similar experience when trying to use later PCIe GPUs (2009 and onward) in some early PCIe motherboards.
They are simply too long to physically fit, bumping into motherboard capacitors, heat sinks, battery holders, you name it.
My retro builds
Reply 4 of 10, by The Serpent Rider
Isolate battery edges and arm. Done. Or you can't install the card into slot properly?
Reply 5 of 10, by Kahenraz
It's not fully inserted. At best, I could replace the surface mount polymer capacitors with a through-hole version with some extra length and tilt it out of the way. But I'm not keen on modifying this card and it's the first one out of several that I've bought so far that actually works.
Reply 6 of 10, by The Serpent Rider
Easiest solution would to change motherboard ¯\_(ツ)_/¯
Reply 7 of 10, by Grem Five
Kahenraz wrote on 2022-04-23, 08:59:
Remote mount the battery
Reply 8 of 10, by Kahenraz
That's what I settled on as the best option, if I want to use this particular motherboard.
Reply 9 of 10, by Tetrium
That's really unfortunate 😒
The Serpent Rider wrote on 2022-04-23, 10:13:
or change the graphics card 😋
My retro rigs (old topic)
Report spammers here!
Reply 10 of 10, by The Serpent Rider
Well, yeah, you can always install GeForce FX 5900XT. Although motherboard deserves an axe anyway.
