First post, by Kahenraz
I always liked vertical CMOS battery holders. Until now.
I thought about moving the capacitors to the opposite side of the board, but they are surface mounted and not through-hole.
240.6 KiB
Reply 1 of 10, by Sphere478
Smaller diameter battery maybe?
Sphere's PCB projects.
Reply 3 of 10, by Joseph_Joestar
I've had a similar experience when trying to use later PCIe GPUs (2009 and onward) in some early PCIe motherboards.
They are simply too long to physically fit, bumping into motherboard capacitors, heat sinks, battery holders, you name it.
Reply 4 of 10, by The Serpent Rider
Isolate battery edges and arm. Done. Or you can't install the card into slot properly?
Reply 5 of 10, by Kahenraz
It's not fully inserted. At best, I could replace the surface mount polymer capacitors with a through-hole version with some extra length and tilt it out of the way. But I'm not keen on modifying this card and it's the first one out of several that I've bought so far that actually works.
Reply 7 of 10, by Grem Five
Kahenraz wrote on 2022-04-23, 08:59:
Remote mount the battery
Reply 9 of 10, by Tetrium
That's really unfortunate 😒
The Serpent Rider wrote on 2022-04-23, 10:13:
Easiest solution would to change motherboard ¯\_(ツ)_/¯
or change the graphics card 😋
My retro rigs (old topic)
Report spammers here!
Reply 10 of 10, by The Serpent Rider
Well, yeah, you can always install GeForce FX 5900XT. Although motherboard deserves an axe anyway.
