ATI Radeon 7500 PCI not working
First post, by Demolition-Man
found this card for a really cheap price, but i think its broken.
Tried it in one of my SS7 Systems: Boot and the usual text mode.
But thats it, anything in DOS gave me a blackscreen. Switched to Win 98 SE, standard graphics driver installation.
Tried to install the 6.2 Catalyst, no compatible graphics card found...
Moved over to one of my early Socket A systems. Better in DOS 9 out of 11 tests worked.
But the same on WIn98 SE. Tried two different drivers, an older and a newer one, but no card for installation was found.
This card appears to be rare? Maybe a special driver is needed? Do you know anything about this card?
Thx!
Reply 1 of 38, by The Serpent Rider
That card looks like a semi-modern chinese knockoff and is not guaranteed to work properly on old hardware. Or well, any hardware in your case.
Reply 2 of 38, by Demolition-Man
So this is some sort of "fake" hardware?
Interessting...
The label on the other side:
Reply 3 of 38, by Ydee
What´s under heatsink?
Reply 4 of 38, by Demolition-Man
We'll find out soon.
Edit:
There is other glue on it, the thermal paste is also very stubborn.
Reply 5 of 38, by bloodem
The Mobility Radeon 7500 on a discrete PCI graphics card. Now that's a true Frankenstein card! 😁
PS: yeah, you got screwed!
PPS: awesome Chinese "warranty void" sticker on that GPU. 😁
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 6 of 38, by dormcat
No legit Chinese company would use a lower case "china" on the label. 😅 It's really rare to see an M7-P on a discrete PCI card.
Reply 7 of 38, by Demolition-Man
This is my first time encountering fake hardware. Too bad there is no driver. Doom 1&2, Duke3D, and Quake work on a PC running DOS. Has to be enough. 😉
Reply 8 of 38, by The Serpent Rider
You can force install specific card model with unpacked driver in Windows 9x. I doubt mobility chip is all that different
Reply 9 of 38, by BitWrangler
Yah, force feed it the driver that matches the chip, probably just a whitelist mismatch on PCI string.
Reply 10 of 38, by Demolition-Man
I don't think it works, but I'll test it again when I get a chance. Thanks.
Reply 11 of 38, by Sphere478
There was another thread somewhere where somebody got one of these. They also had trouble I’m not sure where that thread went, but they eventually ended up returning it I believe and getting a legit card.
I have had very good luck with these
Sphere's PCB projects.
Reply 12 of 38, by Demolition-Man
It was a private purchase from an ebay auction. There is no return option. Really not a big loss and a learning experience, I have no experience whatsoever with the Radeon 7 or 8 series. Otherwise I probably wouldn't have fallen for it. My search for a "fast" DOS/Win98 PCI graphics card continues. With the S3 Savage 4 here I'm already close. The TNT2 models are rare and very expensive here, but maybe I'll find something.
Reply 13 of 38, by T-Squared
I THOUGHT SO! I bought something similar back in 2019, and it was the same quality, but it was an nVidia card instead.
Reply 14 of 38, by matze79
The Card should work in Windows 2000/XP, i`m pretty sure it was never meant to run inside a SS7 PC with Windows 98.
Reply 15 of 38, by Sphere478
Demolition-Man wrote on 2023-08-10, 19:18:
If you have 3.3v pci you could spring for a rage xl that also is a modern made card but people are happy with them usually.
Reply 16 of 38, by dormcat
matze79 wrote on 2023-08-10, 20:39:
The M7-P chip was released back in December 2001 when Win9x was still more common than WinXP; Catalyst 6.2, the last driver supporting this chip, was released as late as February 2005. The chip was designed as an IGP using AGP 4x bus though. The PCB itself was "manufactured" in 2011 when Radeon HD 7500M was around the corner, which didn't make any sense. IMHO the M7-P was recycled from laptops and integrated onto a new PCB to be sold as a "discrete graphics card" to unsuspecting customers.
Reply 17 of 38, by bloodem
What does that mean? There is no such thing on eBay and you are still covered by the buyer protection.
If the item was sold as New or Used and you received a fake card, you can open a case and you WILL win it. It's as simple as that.
Reply 18 of 38, by Ydee
You could try Omega drivers, that member Warlord recommends here: T42 - Mobility Radeon 7500 Driver Help
Anyway, if the card was advertised as a Radeon 7500 (RV200, 2PS-1VS-6TMU-2ROP) and it's populated with a Mobility Radeon 7500 (M7, 2PS-0VS-2TMU-1ROP), it's a scam and I'd give the card back.
Reply 19 of 38, by marxveix
I am 98% sure that with right driver it will work for windows 98, inf edited driver or driver for mobility 7500.
31 different MiniGL/OpenGL Win9x files for all Rage 3 cards: Re: ATi RagePro OpenGL files
