First post, by Bakaneitor
Hello, I have a problem with my Evilking V4 4500, when I place it in the AGP in a correct way it doesn't work, but if I lift it up a bit yes. I was looking and saw that a capacitor was missing. Does anyone know which one to buy?
    227.29 KiB
Reply 1 of 5, by dominusprog
Can you post a larger photo? Are you sure that there was a cap?
Check this link
Voodoo 4 4500 - PowerColor EvilKing IV - AGP 1.5 or 3.3V?
Reply 2 of 5, by TrashPanda
Bakaneitor wrote on 2023-08-18, 05:04:
Sounds like either the slot is dirty/corroded or the edge connector is, clean the connector with some iso and a slightly abrasive cloth.
The slot may need some compressed air and a soft toothbrush to get into the pins, just give it a blast and use some iso on the brush.
Reply 3 of 5, by Bakaneitor
TrashPanda wrote on 2023-08-18, 09:25:
I cleaned the connectors and also tried other motherboards, still the same
Reply 4 of 5, by Bakaneitor
dominusprog wrote on 2023-08-18, 07:49:
Check this link
Yes, it was a capacitor, I saw when it went out but I couldn't find it
