Nvidia TNT2 Ultra driver
First post, by Lylat1an
Is the nVidia Riva TNT2 Final driver in the library here compatible with the Ultra versions of the card?
Reply 1 of 3, by Repo Man11
Phil's Computer Lab has the text of the models covered for each driver version - I've found it to be a quick shortcut for knowing what models each driver covered. https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
Reply 2 of 3, by TheMLGladiator
I recommend driver 6.31 for the TNT/TNT2 cards. Seems to be the best balance between performance and stability from my testing.
Reply 3 of 3, by Gmlb256
Don't bother with later nVidia drivers, stick with the earlier pre-Release 10 Detonators (such 6.31 as TheMLGladiator said or 8.05) if you play early Windows 9x games with that TNT2 card.
