First post, by Lylat1an
- Member
Is the nVidia Riva TNT2 Final driver in the library here compatible with the Ultra versions of the card?
Phil's Computer Lab has the text of the models covered for each driver version - I've found it to be a quick shortcut for knowing what models each driver covered. https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
I recommend driver 6.31 for the TNT/TNT2 cards. Seems to be the best balance between performance and stability from my testing.
Don't bother with later nVidia drivers, stick with the earlier pre-Release 10 Detonators (such 6.31 as TheMLGladiator said or 8.05) if you play early Windows 9x games with that TNT2 card.
