Reply 160 of 182, by Disruptor
RayeR wrote on 2024-04-25, 21:05:
Hi, coming here from 968VL thread. I'm interested more in Virge /V64+ card as I have PCI donors. What is the current state of PCB stock? Are there available gerber files to make order in JLCPCB myself?
The Virge 325 chip internally has a bugged VL interface and uses some functions of the PCI interface that just aren't available on VL.
There is a chance that these quirks may be bypassed with a CPLD but this attempt currently is halted.
Using the V64+ is no problem.
Reply 161 of 182, by RayeR
Ok, I xan use Trio64V+ too. Is there published any pcb design or not yet?
Reply 162 of 182, by Madao
Wait..i'll publishing soon 765VL-000 (a 325VL-Spinoff for trio64V+ VLB ) Give me pleas one or two weeks.
yes, Virge VLB has heavy buggy VLB-Interface ( Trio64V+ has also a bit buggy VLB Interface )
Reply 164 of 182, by Madao
cirrus logic 542x Serie is not comparabel with S3 Trio-Serie
S3 Trio in overall better than Cirrus Logic GD542x and GD542x VLB card is cheap and easy to find. -> it make no sense to make card whit this chip.
But GD542x ISA card is very attractive option.
Reply 165 of 182, by RayeR
Sure, as it waited ~2 years, no hurry 😀
I already have one Cirrus VLB with 1MB so I'm interested in S3 with 2 or better 4 MB DRAM.
Reply 166 of 182, by mkarcher
RayeR wrote on 2024-05-01, 12:38:
Don't get your hopes up on the 765VL for 4MB. As the VLB uses a lot more pins than PCI, because address and data pins are separate, S3 ditched the /RAS pin for the second bank in favour of a pin for the VL interface if the S3 chip operates in VL mode. So it can only access a single bank of 2MB, which is exactly what the 325VL / 765VL supports.
The 765 can be operated in two modes with different pin functions, a legacy mode and a new mode that supports the interfacing with an MPEG decoder. I'm unsure whether the legacy mode on the 765 allows combining VL and 4MB, but a 325VL spin-off will not operate in that mode, because the 325 does no longer support legacy mode.
Reply 167 of 182, by Madao
it is correct, what mkracher wrote. VL Mode and LFB-Mode (Virge supports only new "LFB" )-> max 2 MB, because one RAS output is use as SAUP-input , if chip is running in vl-mode.
Yes, Trio64v+ in legacy mode is capable running with 4 MB and VL-Mode. But ! 4 MB DRAM is on Trio-family is really useless with their RAMDAC with only max 135 MHz pixel clock. (or does someone like interlaced mode? )
Only Virge has gain with 4 MB. Reason: texture memory.
Reply 168 of 182, by RayeR
I think 4MB is good for 2D truecolor mode up to 1024x768. And with 60Hz LCD the 135MHz RAMDAC is more than enough...
Reply 169 of 182, by Madao
Madao wrote on 2024-05-01, 09:27:
pleas don't pull request or make issues call on my github site about (empty) 765VL site. Side is empty and i have reserved name"765VL" .
Many file is ready to uploading, but it hasn't high priority.
Reply 171 of 182, by RayeR
Thank you. When I'll have some more PCBs to manufacture I'll send a batch to jlcpcb. Curently other real-life stuff has higher priority...
Reply 172 of 182, by zami555
Wow, what a wonderfull news. This is one of the projects I definitely must assemble for my 486.
Madao thank you very much for sharing this with whole comunity!
Reply 174 of 182, by RayeR
mkarcher wrote on 2022-04-20, 21:15:
...so you certainly wouldn't undo the LZEXE compression, and patch the byte at offset 0x2d2f from 0x75 to 0xEB.
Hm, seems in my case the decompression went differently (UNLZEXE, Version 2.20), I found at offset 0x2d2f value 0x1E instead of 0x75...
Reply 175 of 182, by seleryba
Do you know if the other variants of Trio64 works as well without changes on the PCB?
I mean:
- Trio64
- Trio32
- Trio64V2/DX (86C775)
- Trio64UV+ (86C767)
Reply 176 of 182, by mkarcher
RayeR wrote on 2024-05-29, 05:35:
I couldn't find that version. UNLZEXE 0.81 does not work (at least executed with msdos.exe in a windows command prompt) on that file. My trustworthy old UNLZEXE 0.4 did work, and produced a file in which the EXE payload is sector aligned after the EXE header, causing a shift of 0xD0 bytes compared to the offset I quoted in that post. The offset I quoted is correct if you use the generic EXE unpacker UNP. So it is very likely that you need to look at 2dff instead of 2d2f. I get 0x1E at 2d2f with UNLZEXE 0.4 as well.
Reply 177 of 182, by RayeR
mkarcher wrote on 2024-05-29, 17:55:
Thanks for the detailed explanation. I used UNP and found the expected Byte at mentioned offset, so patching done 😀
Reply 178 of 182, by Madao
seleryba wrote on 2024-05-29, 12:18:
Do you know if the other variants of Trio64 works as well without changes on the PCB? […]
I mean:
- Trio64
- Trio32
only 765
775 is checked, config strap for BUS interface is fixed to PCI.
Trio64 and 32 doesn't work with this PCB, because pcb is designed for Trio64V+ (LFB mode) and Virge. (different Pinout between LFB Mode and Trio64/legacy mode)
Virge DX (375) is also checked, (same result as 86C775 )
Reply 179 of 182, by seleryba
Madao wrote on 2024-05-30, 05:23:
Thank you for your response.
I have ordered the PCBs and elements, really excited.
One question about BOM - can I use electrolytic capacitors instead of the tantalum ones? I see that on many Trio64V+ boards it has been used like that but I started to wonder if there will be any difference in e.g. image quality. I suppose that the purpose is to filter the power supply to the chip? Is there any cons of doing that?
