Reply 160 of 173, by Disruptor
RayeR wrote on 2024-04-25, 21:05:
Hi, coming here from 968VL thread. I'm interested more in Virge /V64+ card as I have PCI donors. What is the current state of PCB stock? Are there available gerber files to make order in JLCPCB myself?
The Virge 325 chip internally has a bugged VL interface and uses some functions of the PCI interface that just aren't available on VL.
There is a chance that these quirks may be bypassed with a CPLD but this attempt currently is halted.
Using the V64+ is no problem.
Reply 161 of 173, by RayeR
Ok, I xan use Trio64V+ too. Is there published any pcb design or not yet?
Reply 162 of 173, by Madao
Wait..i'll publishing soon 765VL-000 (a 325VL-Spinoff for trio64V+ VLB ) Give me pleas one or two weeks.
yes, Virge VLB has heavy buggy VLB-Interface ( Trio64V+ has also a bit buggy VLB Interface )
Reply 163 of 173, by rasz_pl
Cirrus Logic CL-GD5426-28 ISA cards are plentiful and cheap, while chips are VLB capable. Might be easier to implement seeing they all have integrated DACs.
Tons of NOS cl-gd5428-80qc-a chips at $8 on alliexpress.
Reply 164 of 173, by Madao
cirrus logic 542x Serie is not comparabel with S3 Trio-Serie
S3 Trio in overall better than Cirrus Logic GD542x and GD542x VLB card is cheap and easy to find. -> it make no sense to make card whit this chip.
But GD542x ISA card is very attractive option.
Reply 165 of 173, by RayeR
Sure, as it waited ~2 years, no hurry 😀
I already have one Cirrus VLB with 1MB so I'm interested in S3 with 2 or better 4 MB DRAM.
Reply 166 of 173, by mkarcher
RayeR wrote on 2024-05-01, 12:38:
Don't get your hopes up on the 765VL for 4MB. As the VLB uses a lot more pins than PCI, because address and data pins are separate, S3 ditched the /RAS pin for the second bank in favour of a pin for the VL interface if the S3 chip operates in VL mode. So it can only access a single bank of 2MB, which is exactly what the 325VL / 765VL supports.
The 765 can be operated in two modes with different pin functions, a legacy mode and a new mode that supports the interfacing with an MPEG decoder. I'm unsure whether the legacy mode on the 765 allows combining VL and 4MB, but a 325VL spin-off will not operate in that mode, because the 325 does no longer support legacy mode.
Reply 167 of 173, by Madao
it is correct, what mkracher wrote. VL Mode and LFB-Mode (Virge supports only new "LFB" )-> max 2 MB, because one RAS output is use as SAUP-input , if chip is running in vl-mode.
Yes, Trio64v+ in legacy mode is capable running with 4 MB and VL-Mode. But ! 4 MB DRAM is on Trio-family is really useless with their RAMDAC with only max 135 MHz pixel clock. (or does someone like interlaced mode? )
Only Virge has gain with 4 MB. Reason: texture memory.
Reply 168 of 173, by RayeR
I think 4MB is good for 2D truecolor mode up to 1024x768. And with 60Hz LCD the 135MHz RAMDAC is more than enough...
Reply 169 of 173, by Madao
Madao wrote on 2024-05-01, 09:27:
pleas don't pull request or make issues call on my github site about (empty) 765VL site. Side is empty and i have reserved name"765VL" .
Many file is ready to uploading, but it hasn't high priority.
Reply 171 of 173, by RayeR
Thank you. When I'll have some more PCBs to manufacture I'll send a batch to jlcpcb. Curently other real-life stuff has higher priority...
Reply 173 of 173, by seleryba
Madao wrote on 2024-05-27, 18:02:
JLCPCB after invention of the Madao: 🤑
I am so happy to see this. Thank you mate.
