3dmark99 MegaThread
Reply 340 of 350, by DarthSun
Zen2/XP:
365.07 KiB
Zen2/Win98:
399.8 KiB
Voodoo2SLI world record:
406.17 KiB
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 341 of 350, by AntonPC
Following the tests, here are the results for the Geforce FX 5200 64 bit with 128MB DDR VRAM bus from EVGA. I have to say that I found the 2D quality of this card very crisp 😀
Reply 342 of 350, by AntonPC
The following are the results for the Geforce 4 MX 440 128MB AGP8X 128bit. As with the other tests, v-sync is turned off in the driver.
Maybe the only remarkable thing about this card, besides that only 64MB got recognized during the tests with a 64bit bus 🙁 (maybe it has to do with the motherboard only being AGP4x, faulty contact between the card and the AGP slot, etc) , is that when putting new thermal paste, I noticed the chip is labeled as an engineering sample. 😀
I will try to test it again later and post the results if something changes.
Reply 344 of 350, by AntonPC
sydres wrote on 2024-05-12, 01:18:
I apologize for the weird moire pattern. Got to dig out a CRT monitor
Very good score, and nice setup with the PIII, 440BX and Voodoo 3.
I have a 440ZX (very small board) and hope to bring it back to life as soon as time permits. 😀
Reply 346 of 350, by DundyTheCroc
MB: Asus P4C800
CPU: P4 Northwood 3GHz (HT disabled)
GPU: Asus A9800XT
OS: Win98SE
3DMark99 points: 18581 (no overclock)
354.63 KiB
Reply 348 of 350, by DarthSun
DoZator wrote on 2024-05-13, 19:37:
PCI-e GeForce PCX 5300 (NV37=NV34+HSI) + ForceWare 77.72 (NvOpenGl.dll 71.84):
I didn't even see this CPUID program, I liked it, I made a picture rescue, sets with a loose to days, the Madness Win98 is in the 7900GS x4 PCIe, def clocks, x16 in for GTX.
455.28 KiB
228.6 KiB
Reply 349 of 350, by xelizor
Sorry for the offtopic, are you able to use older dll's with it (like 45.23)?
Best regards
Reply 350 of 350, by AntonPC
Here are the test results for the ATi Radeon 9250 with 256MB VRAM and a 128bit bus. (without the stock fan). One of my favorite cards for a mid end Windows 98 setup. (although these results are in Windows XP) 😀
